Old 23rd October 2008, 07:24 AM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default loudnes control
most simple anlog integrated amps i ve seen when they have a loudness function the volume pot normally has a center tap ( not exactly center but something like that )
i think that this center tap is there to reduce loudnes while volume is going up .....IE loudnes is no longer active as long as volume level is higher than 40%
i ve seen one amp that have loudness switch but there is no center tap on the pot ....
the amp is no longer in my hands and i really dont know if this amp except loudnes switch could perform also the limitation that after 40% of volume the loudnes is decreased
any ideas or circuits ?????
my target is to apply this circuit to vintage amps that volume pots need to be replaced but center tap versions not easilly available and also costumers like to have both working volume and loudnes ....
thanks sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd October 2008, 08:06 AM   #2
Pikefish's Avatar
From wikipedia:
The "loudness" control on a consumer stereo alters the frequency response curve to correspond roughly with the equal loudness characteristic of the ear.[1] The loudness control is intended to make the recorded music sound more natural when played at a a lower sound pressure level.
It's an equaliser, may be implemented by a chip nowdays.
Some Yamaha amps, like one I own, have a Loudness control, another pot next to the bass and treble, I guess it changes the degree to which the response is altered. It was handy to have that extra tweak in my haphazard systems of old.
Old 23rd October 2008, 12:44 PM   #3
Look this schema from:
http://www.belza.cz
regards
Roly
Old 23rd October 2008, 04:43 PM   #4
sakis's Avatar
Default AND....
canyou complete the circuit by telling us where the loudnes switch is connected ?????
and/or the effect of loudnes is active 100% or less ????
Old 23rd October 2008, 07:32 PM   #5
Nico Ras's Avatar
Default Re: AND....
Hi Sakis,
see circuit below for defeat switch. This circuit should be made with a linear potentiometer, the resistor R4 makes it into a log taper.
The loudness control in the circuit is active across the whole range of the potentiometer but decreases in effect with increased volume setting.
SONY's passive pre-amps in their Esprit/EHS range used this exact circuit. The amount of bass boost is set by the ratio of R5/R6 and the frequency by C2 & R5.
SONY did not use the HF boost because of their theory that the human ear LF response reduces by SPL but not HF response.
Frequency setting is independent from the pot setting.
Nico
Old 24th October 2008, 06:22 AM   #6
sakis's Avatar
Default thanks Nico
that looks very nice ...i will give a try and let you know ......
its been a while after we talked in private .....i hope you are doing fine .....
i am ok but very busy
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
Help with control a Stepper motor with an IR-control. Progg70 Parts 1 17th August 2007 05:15 PM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
I want to control 5 LED's with remote control!! W@ldur Digital Source 10 4th August 2005 11:20 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Page generated in 0.09186 seconds (75.62% PHP - 24.38% MySQL) with 11 queries
