quasar amplifier by dr bora 1000 watt - Page 7 - diyAudio
Old 16th August 2012, 09:31 AM   #61
Nice results Joselito! Several people built it without any issues and it should work OK. What was the cause of your trouble with amp in the beginning? First you reported it is distorting and in a next post you are saying it sound nice and clear?!?!
Laonicus Chalcondyles : “Tryballos = Serbos, autem gentem esse totius orbis antiquissimam et maximam, compertum habeo...”
Old 31st August 2012, 08:49 AM   #62
Engel,
The diode drawn is reverse or short circuit it should be otherwise.
Edwin
Old 31st August 2012, 09:30 AM   #63
Sir Boraomega,
It was a power supply problem where my friend Edwin here had plugged the transformer to a 100 vac source instead of the 220 vac. With that condition the power amp is low voltage and perform poor with 1000 watt 8ohm load. With the right power source it drives the load strong and clear. Thank you for the brilliant design you shared to us.
Engel,
I used the original IRFP240 specified by Sir Boraomega and had no chance of locating the IRFP460s. My friend Edwin now is also building one for him, he is not yet registered in the forum. Thanks
Joselito
Old 31st August 2012, 10:18 AM   #64
Default IRFP250
could you use IRFP250 instead of IRFP240? I have tons of IRFP250 available.
Thanks,
Borut
Old 27th October 2013, 11:35 AM   #65
Originally Posted by engel dela pena View Post
joselito,
sir bora noted not to use irfp460 to me because of parasitic oscillation issue,what fets you use?
how do you implement the diode is this right?
pls see attachment
Old 24th November 2014, 11:19 AM   #66
pallab is offline pallab  India
sir,i have 8 pair IRFP460 ..so is there any problem if i use these IRFP460 instead of IRFP240 in D Bora LEGEND QUASOR amps???? please reply me..
Old 25th November 2014, 06:08 AM   #67
so..how many components i have to replaced in this circuit???
please some one reply me.....
Old 25th November 2014, 06:15 AM   #68
image link..
https://www.facebook.com/photo.php?f...type=1&theater
so...how many components i have to replaced in this circuit...to run it +-90v rails????please some one help me..
Old 25th November 2014, 09:33 AM   #69
For work on +-90V you do not have to change anything. I am suggested that you use IRFP240 only.
Old 25th November 2014, 06:02 PM   #70
FQA32N20C might be even better choice for output than IRFP240.
1000 watt amplifiers boxcustom Car Audio 32 31st May 2011 05:49 PM
Help With A 500 Watt subwoofer and a 1000 amp Bgpoet Solid State 2 30th December 2008 08:41 AM
bora techno amplifier power supply djronbxs Solid State 9 4th October 2008 02:35 AM
1000 Watt with usb input ! cph2000 Class D 1 4th October 2007 07:04 AM
NEW Dayton 1000 Watt Subwoofer Plate Amplifier - CHEAP! BHTX Swap Meet 0 28th December 2006 06:08 AM
Copyright ©1999-2017 diyAudio
