Onkyo SR705 NEWB Needs Help
Old 22nd October 2008, 10:26 PM   #1
litezoner is offline litezoner  United States
Default Onkyo SR705 NEWB Needs Help
This unit powers on for a moment and then shuts itself down after about 5-10 seconds, where would I look first?
Thank you
Old 23rd October 2008, 03:10 AM   #2
ostripper is offline ostripper  United States
ostripper's Avatar
Sounds like a blown output device making dc.
protection circuit
kicks in, saving you from smoke and fire.
With a multimeter look for white ceramic block with 3 pins
sticking out top near heatsink , measure middle pin
of each. Any one that does not read 0 volt before amp
shuts off is the channel blown.
Old 23rd October 2008, 03:30 AM   #3
Thank you, so check the middle pin when I power it up, should be 0 volts with power on? and this would be DC Volts? so ground the black end of the dmm to the chassis? Thank you again
Carl
Old 28th October 2008, 03:36 PM   #4
steven344 is offline steven344  United States
steven344's Avatar
Default onkyo
Check all the transistors on the heatsink for shorts between collector and emmitter,middle pin and right pin also the white resistors can open up.You can also have the driver and bias transistor go bad when the output shorts and take out other transistors and resistors .If all other parts are not check it will blow again .I trick is to put a 100 watt 120volt lamp in series with the amp your working on to prevent damage when you replaced parts.
Old 28th October 2008, 03:36 PM   #5
steven344's Avatar
Default onkyo
Old 28th October 2008, 03:57 PM   #6
steven344's Avatar
The txsr605 manual you sent me should help you with the txsr705 your working on ,most brands dont change much between years as long as the are about the same age..Look at the schematic of the ouput section and check outputs ,drivers bias transistor and resistors.
Old 2nd November 2008, 02:12 PM   #7
Well Folks, This seems way beyond my knowledge and expertise area, anybody live near Temecula California that would like to service this unit for me, I will ship if nessasary. What do you suppose would be a ballpark worst case sanario as far as cost to repair? Let me know if anybody local? or is interested?
Carl u4shop@aol.com
Old 20th November 2008, 04:02 PM   #8
steven344's Avatar
Default onkyo and Yamaha
Hello,Im working on a onkyo and a yamaha with blown output stages and almost glad I dont fix these as a fulltime job anymore.It really bothers me that they cant put bottom covers on audio equipment like they used to.The whole thing has to be taken apart just to change the output transistors and other common parts.These are made to be thrown away when the output stage goes which is the most common thing.
Onkyo SR705 NEWB Needs HelpHide this!Advertise here!
Onkyo SR705 steven344 Solid State 0 28th October 2008 04:00 PM
A newb trying it out. Svenhook Parts 3 28th August 2005 08:27 PM
Hello from a newb biff_mckeagan Introductions 8 16th January 2005 07:43 PM
Sub and Amp help for a newb pinangsia Car Audio 2 14th September 2004 05:28 AM
Amp For Newb meta Pass Labs 7 9th July 2003 06:22 PM
