Ayre's KX-R reviewed in November 08 Stereophile
Old 26th October 2008, 11:42 PM   #31
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
terry:
that makes sense to me, too.
i was worried that changing the degeneration could change the spectral balance of the distortion, which doesn't sound like something you'd want to do when changing volume. however, (apologies to john) i have to admit i haven't thought it through.
i need my wife to go on a shopping trip so i can have time to play with some ideas ...
maybe justcallmedad will pop over soon and talk about his experiments ...
Originally posted by Terry Demol
PMA,
Variable 1st stage degeneration??
On a fully balanced, open loop design why would you do it any otherway?
cheers
Terry
Old 27th October 2008, 12:17 AM   #32
john curl is offline john curl  United States
john curl's Avatar
We have used variable source degeneration in mike input amps in the past. It is Charles' way to be ahead of the pack, so to speak. So far it has worked for him.
"Condemnation without Examination is Prejudice"
Old 27th October 2008, 05:38 AM   #33
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
John,
'....because it usually has a time constant included in it that is called the 'dominant pole' that is often in the audio range, and sometimes below 10Hz.'
One way around this is to use a CFA topology - its then very easy to put the dominant pole way above the audio band. I think its easier in CFA's (discrete) to tailor the open loop gain as well. My next pre-amp will do this with, I am planning, switchable loop gain from the front panel via some small signal relays. Should be interesting to compare how the sound is affected, but first I will complete my 4562 based design in the next 4 weeks.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 27th October 2008, 02:20 PM   #34
diyAudio Member RIP
Congratulations are due for a good sounding line level pre-amp @ $18,500 ?
/sreten.
Old 27th October 2008, 07:05 PM   #35
chengtaw is offline chengtaw
my friend, an owner of Ayre's KX-R(serial no. 1xx) keeps complaining the low gain.......................
Ayre's KX-R reviewed in November 08 StereophileHide this!Advertise here!
SIs Son of T-Amp reviewed in 6moons PauSim Class D 15 9th October 2005 09:45 PM
NW DIY EVENT November 22 RAW Multi-Way 3 24th November 2003 07:32 PM
November NEWSLETTER from A.C.A. skaloumbakas Analogue Source 0 14th November 2003 12:00 PM
November 11 Fred Dieckmann Everything Else 15 13th November 2002 03:59 PM
Copyright ©1999-2017 diyAudio
