Ayre's KX-R reviewed in November 08 Stereophile - Page 3 - diyAudio
Old 26th October 2008, 01:17 AM   #21
john curl's Avatar
When I finally made the breakthrough with the Grateful Dead, I designed a line amp with 20K open loop bandwidth. That became the Levinson JC-2 line amp, because Mark Levinson evaluated it as well. Why?
"Condemnation without Examination is Prejudice"
Old 26th October 2008, 01:33 AM   #22
Why, what?
Is this a quiz?
The JC means John Curl, the number 2 indicates that it the second line amp.
You are also using the same number now on the Parasound JC-2
Old 26th October 2008, 03:39 AM   #23
john curl's Avatar
The answer is the reason for this thread.
Old 26th October 2008, 06:41 PM   #24
Aha ok.
Old 26th October 2008, 10:18 PM   #25
john curl's Avatar
I should be more clear. The original Levinson JC-2 and the Parasound JC-2 share one quality approach: Fets where possible, class A operation, balanced topology, high open loop bandwith. This works for me, but it is not shared by many quality IC designs.
The JC-2 always follows the JC-1. It is an interesting parallel that Parasound called the preamp the JC-2, when Levinson did the same thing 35 years before, or in 1973. In Levinson's case the preamp followed the JC-1 pre-preamp, and in Parasound's case the preamp followed the JC-1 power amp. I allowed this to happen, but I did not initiate it.
Old 26th October 2008, 11:02 PM   #26
Terry Demol's Avatar
Originally posted by PMA
I believe that Charles is only waiting for a good question on a "Variable Gain Transconductance" .
PMA,
Variable 1st stage degeneration??
On a fully balanced, open loop design why would you do it any other
way?
cheers
Terry
Old 26th October 2008, 11:46 PM   #27
John
Thank you for being clearer.
I do agree in what you are writing, but must admit that Iím not using many Fetís.
I use BJTís with cascode and of course CCS and current mirror.
Maybe I should try to use some more fetís.
What did happen with the Vendetta Company and products?
Wouldnít there be a market for the active x-over now that more and more people are looking for an active solution instead of putting a lot of Cís Lís and so on between the amp and the loudspeaker?
And it is good to know that you didnít initiate the use of the same name on the products.
Stinius
Old 26th October 2008, 11:48 PM   #28
john curl's Avatar
The use of first stage degeneration SHOWS that Charles is OK with local source degeneration or local feedback.
Old 26th October 2008, 11:52 PM   #29
Originally posted by Terry Demol
PMA,
way?
cheers
Terry
I donít think he is talking about degeneration, but about the volume control.
Stinius
Old 27th October 2008, 12:07 AM   #30
Stinius
Variable degeneration = variable transconductance = volume control
SIīs Son of T-Amp reviewed in 6moons PauSim Class D 15 9th October 2005 10:45 PM
NW DIY EVENT November 22 RAW Multi-Way 3 24th November 2003 08:32 PM
November NEWSLETTER from A.C.A. skaloumbakas Analogue Source 0 14th November 2003 01:00 PM
November 11 Fred Dieckmann Everything Else 15 13th November 2002 04:59 PM
Copyright ©1999-2017 diyAudio
