Old 21st October 2008, 04:03 PM   #1
tarka25 is offline tarka25  United Kingdom
Default Crest Audio 4801 PSU Capacitors
I was wondering if anyone knew where to source the 17,000uf 55v capacitors that appear on the power supply pcb.
I have searched, but cannot find the ones in the correct package size, they all seem to be 2.5" diameter.
Many thanks
Diane
Old 21st October 2008, 07:38 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
try to find some 15.000 or even 10.000 uF
can not be very critical
lineup
Old 22nd October 2008, 12:36 AM   #3
KBK is offline KBK  Canada
show us the type (mounting) and size of the given capacitors. If anything, go for slightly more capacitance, not less...as most commercial designs are a hair skimpy with energy storage.
All sizes are standardized if they are snap mount or 2.5" diameter screw in type. If it is an amplifier that is more than about 10 years old, nowadays..there is likely to be a better quality and slightly bigger cap for that given can size.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 23rd October 2008, 05:15 PM   #4
They are 1.5"dia, 3 pin snap in and approx 3" high.
I'm a little nervous at changing the values as there are 4 caps all linked in parallel, I could change them all if I was changing values, bur realistically it's going to cost in excess of £60 to do that, so I would rather source one that could just be swapped in.
Crest Audio Schematics Needed and more? spirus Solid State 14 3rd April 2008 12:06 AM
Re-building Crest Audio LT1000 darw82 Class D 7 20th May 2007 09:11 AM
crest audio power amplifier hienrich Solid State 7 18th January 2005 12:28 AM
Best capacitors for Audio?... VS Pass Labs 15 9th January 2005 02:08 AM
Page generated in 0.07620 seconds (70.64% PHP - 29.36% MySQL) with 10 queries
