Old 20th October 2008, 09:34 PM   #1
Default Mosfet problems
Hi guy's,
I hope you can help me out here?!
Over here the 2sk-405 and 2sj-115 are obsolete.
What are usable replacement type's for those?
I dont know if i can use the 2sk-1530 and 2sj-201???
Thx!
Old 21st October 2008, 02:36 AM   #2
fab is offline fab  Canada
fab's Avatar
Hi
The 2SK1530 seems a good choice based on the datasheet (similar VGSoff, higher max current and voltage). Its transconductance is even more than twice the one of the 2SK405. Capacitance is about twice though. The zero temp coefficient is higher with the 2SK1530 (8A compared to 4A). These differences are not usually major but without seeing the amp schematics it is difficult to know for sure...
Old 21st October 2008, 07:29 PM   #3
turnA_zpoint's Avatar
Hi!
As a sample case ... in case of 2SK1529/J200 they were different max voltage from 2SK1530/J201, I was able to replace K405/J115
The case ,the gate resister was 470ohm -1000ohm,
the source resister was 0.1ohm -0.22ohm,
and by adjusting the voltage of the bias,
However, if it doesn't gradually enlarge the voltage of bias from a small value, might be damaged.
For only one sample case .
(I can not say sure ,as not seeing the schematic...,too. sorry)
Regard
BiCMOS Bipolar+MOSFET better than MOSFET lineup Solid State 5 8th December 2009 11:46 AM
Maplin mosfet problems bobcat Solid State 1 15th July 2009 08:58 AM
amp problems and need help please supra01halo Class D 0 10th February 2006 07:42 PM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
Any problems with Fun-Tak (tm) on the PCB? fotzepolitic Solid State 10 1st February 2004 03:35 AM
Page generated in 0.07340 seconds (68.85% PHP - 31.15% MySQL) with 10 queries
