Old 17th October 2008, 04:11 AM   #1
pureh2o is offline pureh2o  United States
Default Please help with NAD 1020 Pre-amp
Hi there. I need your help. I need to know the values of two electrolytic capacitors in my NAD 1020 Pre-amp. They are located on the board about 1 inch behind the treble pot. They are marked C533, and C531. Thank you for your help. John.
Pureh2o
Old 17th October 2008, 05:27 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
I do not know if this schema can help
http://www.diyaudio.com/forums/attac...amp=1124659687
from this topic
NAD 1020 Preamp Problems
this is what previous stuff can be found about NAD 1020
http://www.google.com/search?q=+site...%22nad+1020%22
lineup
Old 17th October 2008, 06:03 AM   #3
Default Nad 1020 help
Thanks Lineup, but it does not give me the values. Thanks anyway for your help. John.
Pureh2o
Old 17th October 2008, 08:30 AM   #4
Mooly's Avatar
Are they missing or something ? No markings on the originals ? Lineups link shows only one as an electrolytic, but I think I can make out some kind of text on there. C531 = 0.12 mfd ??? and C533 = 4?? could that be 0.47mfd or 4.7 mfd. You certainly won't harm anything if you get it wrong. 0.47 is a value that could be an electroylitic but it's small.
Old 17th October 2008, 09:13 AM   #5
lineup's Avatar
this is the preamp section of NAD 3020 ( http://www.tcaas.btinternet.co.uk/index-4.htm )
There are two R531 and R533, but no capacitors with these numbers.
The values is in the lower channel. some values not easy to read.
lineup
Old 17th October 2008, 05:27 PM   #6
Default Need Help With NAD 1020
Mooly, Lineup, The schematic you sent me Mooly is close to the 1020 but it ended with C528. It appears that the pre-amp section of the 3020 is not exactly the same as the 1020, but close. Lineup, Your schematic shows C531, and C533, but does not give values. Oh, these are Caps, not resistors. My grand daughter decided to grab these and play with them outside, and I can't find them. But thank you guys for your trouble, I really appreciate it. Maybe someone will have the schematic for the 1020. Again thanks, John.
Pureh2o
Old 17th October 2008, 06:35 PM   #7
Mooly's Avatar
What about the ones in the other channel, or have they gone walkies
Old 17th October 2008, 08:50 PM   #8
zoranaudio's Avatar
Hello!
I made a NAD 1020b pre-amp clone long time ago, so I got pcb scans and all values of the components, but did not find the original 1020b schematic, but as I compared with other models of NAD integrated amps, the schematic is quite similar or equal in some parts.
So this is what I wrote for C:
C533=47microF/35V
C531=47microF/63V
This is from the original 1020b I made a clone and still listen on it.
I hope I will help you.
zaudio
Old 17th October 2008, 09:05 PM   #9
zoranaudio's Avatar
John!
I hope I helped you, cos this is taken from original NAD 1020b device.
If you find the original schematic I'll be happy.
I made this clone just with PCB,s scans and copying the values of all parts!
If you find schematic please e- mail me:
z37hwxzoki@yahoo.com
Best wishes from z37hwx HAM radio-amateur station
73 de ZOKI
zaudio
Old 18th October 2008, 09:55 AM   #10
lineup's Avatar
C533=47microF/35V
C531=47microF/63V
Are these the same 47uF caps as C524, C523 in my posted schematic?
lineup
Schematics needed for a Marantz 1020 Giaime Solid State 22 31st May 2008 07:29 AM
NAD 1020 Preamp Problems gmilitano Solid State 54 24th March 2006 03:42 PM
FS: Lightware L-1020 projector Lusso5 Swap Meet 0 27th January 2005 05:49 PM
kenwood KAC 1020 amp emarald Solid State 4 7th January 2003 05:30 PM
Page generated in 0.10997 seconds (77.68% PHP - 22.32% MySQL) with 11 queries
