Hi all,
I just replaced the TL072CN from my preamp with the "better" opa2134. The result is better highs more clear but the lows are not so punchy as with tl072cn. Is it me or this is the case? Any other experiances, or thoghts are welcome. Is this correct behaviour. Attached the schematic. |
#2 |
check your schematic.
regards Andrew T. |
#3 |
Have you tried to copy ( to draw ) the circuit from a piece of equipment or have you actually built it like the circuit shows
#4 |
kzeprf22,
It seems the opa2134 uses at least twice as much current as the TL072. What does the power supply for the OpA look like? Regards |
#5 | |||
Thank you all for the answers.
The truth though is I done it a little bit quick this one, and I am thinking that something is wrong mechanicaly between the opamp base and the opamp. Maybe the opa is not conducting properly. I will check as soon as I find time and I will get back. Thanks |
#6 |
R1 at 1 ohm does nothing. R2 puts an unwanted extra load on the opamp output. Omit it. C1 and R3, only you know
#7 |
if this is supposed to be a unity gain topology then far too many components have been fitted.
If it's supposed to be a gain of 1.9times (+5.6dB) then R2 is attached to the wrong node. I think the output resistor of 75r is necessary since the tl07x series are reputed to be very bad at driving capacitive loading. The 75r should be located right next to the output pin of the opamp. If R1=1k0 then it is there to minimise output offset by providing a resistive route for the input offset current. But 1r0 does nothing and even 1k0 will hardly change the output offset since tl07x are FET input opamps.
regards Andrew T. |
| Help replacing TL072CN op amps for TLE2072CP | SoundSpot | Solid State | 4 | 23rd December 2008 11:31 AM |
| capacitors need to be replaced? | anton | Parts | 2 | 1st December 2007 01:00 PM |
| can be MJE2955 be replaced??! | nbcd | Solid State | 1 | 6th November 2003 07:06 PM |
| How i replaced my dust cap... Vol 1 | speekergeek | Multi-Way | 10 | 31st October 2003 03:20 AM |
| Page generated in 0.08585 seconds (76.87% PHP - 23.13% MySQL) with 11 queries |
