Old 15th October 2008, 10:34 PM   #1
gain is offline gain  United States
gain's Avatar
Default My version of a Slone preamp
from "The Audiophile's Project Sourcebook" page 65 fig 3.1. I omitted all the RIAA circuitry (already have a RIAA board) and just built the preamp section twice for stereo. the board on the right is the preamp and the board on the left is the psu (just in case someone doesn't know by looking).
for the preamp i used 2/4 of a TLO74 opamp chip, and just grounded the input pins of the two unused ones. all caps in the signal path are tantalum and all resistors in the signal path are metal film. level adjustment is done via the two 20K pots at the top and bottom of the picture (one adjusts left channel the other adjusts the right)
my assessment:
since the only measuring instruments i currently have at my disposal are a VOM and my ears, i apologize for not being able to give a more objective analysis and measurements. my opinion is it sounds very nice and worth building. highs are crisp and accurate, mids are clean and lows are powerful and smooth. no perceivable hum or noise or buzzing issues, so im assuming PSRR is very good. a very wide range of level adjustment is possible with this circuit, from off to making a receiver thats set on 1 sound like its on like 6 or 7 in volume.
this is part of a larger project that will also include source selection, tone controls, level indicators and a RIAA board all in one box.
all comments, suggestions, questions and observations welcome.
Old 15th October 2008, 10:35 PM   #2
gain's Avatar
PSU schematic
Old 16th October 2008, 02:26 AM   #3
jaycee is offline jaycee  United Kingdom
TBH from looking at the PCB and summarizing (havent seen the book) there isn't much going on here. An opamp based preamp is a pretty simplistic thing.
There are easy improvements to make - the first would not be using tantalum capacitors. Polyester are much better here for coupling purposes. If they are small value capacitors used for bandwidth limiting, polypropylene work very well. Stick with ceramics for decoupling.
The PSU is easily improved - instead of using the 7815/7915 pair, use LM317/337 with the adjust pin bypassed by a 10uF capacitor.
The TL074 opamp can be easily replaced especially if you are only using two opamps - NE5532 works well, or OPA2134 if you prefer a FET based opamp.
A few projects you might wish to check out:
http://sound.westhost.com/project02.htm (for reading)
http://sound.westhost.com/project88.htm
http://sound.westhost.com/project97.htm
http://sound.westhost.com/project05b.htm
Old 16th October 2008, 03:06 AM   #4
gain's Avatar
Hi jaycee, thanks for your reply!
yes i know. this was really my first diy audio project building from scratch so i went for something simple. also i needed something like this because the signal from my ipod does a poor job at driving the input to one of my vintage receivers, hence the need for the opamp to boost the signal.
actually that was a typo. i used the tantalums for opamp decoupling, and in one place in the signal path where the schematic specifically called for it. all the rest are garden variety ceramics i had on hand, so yeah i realize theres much room for improvement here. if i decide to build a six channel version of this for my home theater, then i will definitely take your advice and invest in some boutique caps. but as it is and for what i'm using it for, it sounds just fine to me the way it is.
i thought the 317 was an adjustable regulator? i was going for a +/- 15V split supply hence my reason for using the 78/79 series so could you explain why 317/337 is better here?
good to know and thanks for the input. i used the TLO74 simply because i had a few on hand and also because Slone recommended them as a possible choice for this design.
thanks, i most certainly will check these out.
Old 16th October 2008, 03:37 AM   #5
gain's Avatar
i have noticed something interesting this circuit does.
ground both inputs. turn both level controls to any setting you want, turn volume on receiver/power amp up to max. then, there is a very very slight mains hum in the woofer. i mean its so slight i have to actually stick the side of my head into the woofer cone to allow my ear to detect it. but sure enough, its hum. heard hum enough times to recognize it the instant i hear it. unfortunately.
whats confusing me is this. after disconnecting my circuit from the mains, the hum continues unchanged until the filter caps in the PSU discharge through the bleeder resisters enough to turn off the opamp ... which in my case is about four seconds. then the hum goes away completely.
so in other words the hum isn't coming from the trafo, because it continues when the primary is unplugged from the mains. it can't be being injected in the power amp or the rca cable from the power amp to my circuit, because the hum stops when the circuit is shut down.
so whats happening? regulator noise? hum pickup by the grounding system or some component on the circuit board? i mean this problem is barely noticible and is undetectable (to me) other than in the condition i described above, so its not like im in a hurry to fix it or anything.
just curious as to whats making it behave like that.
Old 16th October 2008, 03:47 AM   #6
gain's Avatar
just switched to all sheilded cable for external signal lines.
situation unchanged. perhaps use shielded cable for the lines to the pots too? just figured i'd see some sort of improvement if i was on the right track.
Old 16th October 2008, 04:09 AM   #7
lineup is offline lineup  Sweden
lineup's Avatar
Hum can come from GROUND rail.
Can also be because TRafo is too close to input. But this is not in your case.
It is important to keep the INPUT ground 0V rails separate from other components that connect to ground.
Input ground should have a separate wire/rail to the Common 0 Volt point of your both regulators.
In the figure this is:
- the GND of Volume Pot
- the point below R18, 1 Mohm
Other grounded components, like Load connected to Output, Supply filter caps should have another wire to Regulators 0 Volt point.
Regarding opamps:
For this application, a line preamplifier, you need not to use any other opamps than TL071,TL072, TL074.
They are good enough both regarding low noise, low distortion.
As slone mentions the RIAA part have very low distortion with these JFET opamps.
There are no other opamps that can give this adequate audio quality for same price.
I attach schematic, so people can follow this project better.
Lineup
lineup
Old 16th October 2008, 07:36 AM   #8
Good idea
Tants have a very bad rep for doing nasty things when they get old and wobbly. For decoupling, good electrolytics are OK, and ceramics are apparently preferred over polyester etc because of their better response at HF - mylars as Slone showed also work well.
For signal coupling there is polyester and then electrolytic - some would say that electrolytics dont belong in the signal path, but sometimes it is neccesary and IMO, preferable to tantalums. Polypropylene or polystyrene capacitors are preferred for filters and compensation because they hold their tolerance well.
LM317/337 has a lower noise output than the 78/79 series, especially when the adjust pin is bypassed with a capacitor. They aren't much more expensive, and there is only minimal extra work in using them, so it is worth it.
TL07* is fine for experimenting, they are cheap enough I can't comment as to why Slone recommends them, possibly because this is a "beginner" project and the TL's are an available and cheap FET input op-amp.
Check out Rod's website in general - there is loads of great projects and articles to be had there! It certainly helped me a lot when I was first getting into audio electronics.
Old 16th October 2008, 02:11 PM   #9
gain's Avatar
Hey lineup, good to see you again. thanks for your input on this.
so just like in a power amp eh? good to know and i was actually considering running separate wires for the input/signal ground and the ground the opamp decouple caps connect to if i ran into a serious hum problem. but this hum is so so very slight as to be unnoticeable except at max volume with no sig applied, so i'm trying to decide if its worth the effort. probably will do it just for experimentation purposes. and to get into good construction habits.
Regarding opamps:
Lineup
yeah i'm happy with the sound of the '74. i'm not exactly a golden ear dude either tho so it may be making noise and/or nonlinearities that i can't perceive (nor measure because i dont have a scope ... yet)
thanks for attaching the schematic. i was going to but wasn't sure about copyright issues so thats why i didn't.
Old 16th October 2008, 02:23 PM   #10
gain's Avatar
Jaycee,
thanks for your reply, some really good info in there.
regarding the tantalums ... didn't realize they deteriorated in such a manner with age. i will seriously consider using good quality electrolytics or polyester instead as you recommend. you may have just saved me who knows how many hours of frustration and/or grey hair genesis in the future debugging circuits with 'wobbley' tants so i appreciate you telling me this fact very much.
also very good to know about the better noise performance of the 317/337 series regulators. whats the normal way to set these up? wire them up like a normal adjustable regulator, then 'adjust' them to 15V (or whatever you need) then measure the resistance you have the pot set to and replace the adjustment pot with a fixed R? will research PSU's that use 317/337 for fixed supplies for design ideas, thanks.
i spent some time on Rod's website last night and yes it does indeed have a LOT of good projects and info. planning on reading more just as soon as i have some free time.
thanks again Jaycee and take care.
New DISPRE preamp, successor to previous popular version PMA Analog Line Level 638 4th May 2010 07:21 PM
Beginner: Slone Preamp scott_jcp Chip Amps 13 9th February 2005 12:16 AM
Page generated in 0.14206 seconds (89.60% PHP - 10.40% MySQL) with 11 queries
