AD797, how to make the best of it
Old 15th October 2008, 08:15 PM   #1
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
Default AD797, how to make the best of it
In an attempt to do a discrete vs monolithic folded cascode opamp shootout, I've breadboarded an amp for my favourite opamps - AD797 as left/right and AD829 comp pin out as active ground.
I simulated AD797 and AD829 in LTSpice and came up with the schematic below. While a 22 pF cap for the distortion cancelling circuit simulated the best, a 47 pF one as suggested in the data sheet sounds better. I put this cap from the buffers output to pin 8 as proposed by Walt Jung. This cap is absolutely essential to get a good sound from AD797. Without it it sounds worse than NE5534.
Much have been said about AD797, and how cranky it is, but I've had a hard time finding schematics showing a good implementation. So, please tell me how to get the best of this great opamp!
Old 15th October 2008, 08:18 PM   #2
Ground channel is using a TLE2426 as rail splitter and virtual ground for the small signal returns and this for the headphones return.
Old 15th October 2008, 08:31 PM   #3
aparatusonitus is online now aparatusonitus  Croatia
aparatusonitus's Avatar
Hi nelson,
Sorry, but I don't get it: you have chosen high impedance node from AD829 for your active ground, as well as LED CCS (again high impedance) for AD797 supply? Could you elaborate please?
Edit: Ah there is another sch
Non mai abbastanza...
Old 15th October 2008, 08:45 PM   #4
Originally posted by aparatusonitus
Hi nelson,
I'm not so clever. I used LED CCS since it was what I had at hand, and it could be squeezed inside the small box I use. I prefer JFETs because of simplicity but i don't have any with that idss, 30 mA something. What CCS would be better? Do you think just using resistors, say 100R, would be better than this CCS?
Old 15th October 2008, 08:46 PM   #5
juma is online now juma  Germany
juma's Avatar
Hi Nelson !
Did you build the circuit with AD797 or your conclusions come from simulations?
Sorry, but it's not clear from your post - you wrote about simulations and you comment on sound in the same time. It would be nice to know about real life circuit because I used AD797 only as a unity gain buffer.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 15th October 2008, 08:50 PM   #6
Originally posted by juma
Hi Nelson !
Yes, I've built it. Most parts are on sockets for tweakability.
Old 15th October 2008, 08:58 PM   #7
You are using LED based CCS to supplay power to AD797 (pins opa+/-), but intristic property of every CCS is that they represents high impedance output, you need as low as possible impedance from PSU, regulated or not.
Old 15th October 2008, 09:03 PM   #8
martin clark is offline martin clark  Europe
The clues are all in the datasheet; read it closely - it's excellent.
One essential item is the input damping resistors, min. 100ohms , at the 797s signal inputs. Everyone leaves them out, then wonders why the 797 is 'cranky'! It isn't - it's simply a very high performance part, and one cannot expect simply dropping it into conventional 'jellybean opamp' circuits to get the best out of it.
Old 15th October 2008, 09:06 PM   #9
So I shouldn't use CCS to the opamps at all? The amp is powered by two 6F22 NiMH batteries in series. I can try to bypass the CCS and see what it does to the sound, but that will be tomorrow since it's getting late now.
Old 15th October 2008, 09:10 PM   #10
I'll try to increase these resistors tomorrow as well.
Thank you for your suggestions.
AD797, how to make the best of itHide this!Advertise here!
Tips for AD797 ?? redrabbit Everything Else 11 2nd October 2008 04:55 PM
AD797 Clone people! Who can make a better one. lineup Solid State 71 2nd July 2007 08:17 AM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 07:06 AM
Ad797 audioPT Parts 12 31st October 2003 09:07 PM
