Old 20th October 2008, 11:08 PM   #51
syn08 is offline syn08  Canada
Originally posted by Patrik Floding
Can it sound good even if oscillating like mad behind the scene (of my 100MHz 'scope)?
No, you are probably fine. AD797 is not very difficult to handle if good layout principles are employed. To figure out what "difficult" means, you should try something like the OPA847 or AD8056...
Old 20th October 2008, 11:45 PM   #52
Thanks for the reply!
Layout isn't great, but at least the decoupling is right at the OpA.
Old 21st October 2008, 10:09 AM   #53
Bonsai is online now Bonsai  Taiwan
The advantage of super-shunt regulators is that, if you organize the circuit correctly, the ground return currents are constant. You can see immediately that it there will be a reduction in noise injection between the different circuit s both into the power rail, and into the signal lines (here, because there is always a finite ground return resistance, so Is*Rgnd + Vsig is avoided).
For this to work effectively, th e variuos stages in th e circuit need to be partitioned carefully and local tight loop super shunt regulation applied to these individual stages.
I think if you apply super shunt regulation without partitioning correctly, you will not get the full benefit.
bonsai
http://www.hifisonix.com/
Old 21st October 2008, 10:22 AM   #54
lineup is offline lineup  Sweden
lineup's Avatar
this should be true for shunt regulators
as well as zenerdiode references
lineup
Old 22nd October 2008, 02:32 AM   #55
Line-up, not neccessarily so. If the supply voltage changes, the current through the ground return will change as well. If the shunt is fed from a current source, the ground return current is fixed.
bonsai
Old 22nd October 2008, 03:00 AM   #56
Hartono is offline Hartono  Indonesia
constant ground return current .......illuminating ^^
also constant power draw IIRC
You tried your best and you failed miserably. The lesson is 'never try'.
Homer Simpson
Old 22nd October 2008, 01:08 PM   #57
lineup's Avatar
right
lineup
Tips for AD797 ?? redrabbit Everything Else 11 2nd October 2008 04:55 PM
AD797 Clone people! Who can make a better one. lineup Solid State 71 2nd July 2007 08:17 AM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 07:06 AM
Ad797 audioPT Parts 12 31st October 2003 09:07 PM
Page generated in 0.09026 seconds (74.81% PHP - 25.19% MySQL) with 11 queries
