Old 14th October 2008, 09:27 AM   #1
MiiB is offline MiiB  Denmark
Default Power Amp Design
Hello...
I have worked arround a bit with an amplifer design..
Its based arround a J-fet input . that is a little unconventional coupled as a little of the signal is fed to the corrent source for the second stage..
The amplifer simulates wery well with very low distortion and a quite unique distortion distribution as the second harmonic dominates by a factor 10 to the third...
All in all a rather promising design..
I have som questions regarding the output stage...
Would it be possible to omit the predrivers as I already have rather powerful transisters arround the bias spreading diode string.. and the drive the drivers directly..?
I have made a DC-coupled feedback is this desireable or must I insert DC-blocking... ??
if so I have to raise impedance in the feedback loop by app. a factor 5
Old 14th October 2008, 09:36 AM   #2
DC component:-0.00176547
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 8.162e+00 1.000e+00 180.00° 0.00°
2 2.000e+03 3.483e-04 4.268e-05 90.14° -89.85°
3 3.000e+03 2.063e-05 2.528e-06 -177.61° -357.61°
4 4.000e+03 5.119e-07 6.272e-08 -107.15° -287.14°
5 5.000e+03 1.872e-07 2.293e-08 -179.65° -359.64°
6 6.000e+03 2.682e-07 3.287e-08 176.29° -3.71°
7 7.000e+03 3.419e-07 4.189e-08 179.23° -0.77°
8 8.000e+03 3.360e-07 4.117e-08 -178.04° -358.04°
9 9.000e+03 3.677e-07 4.505e-08 179.32° -0.68°
Total Harmonic Distortion: 0.004275%
Old 14th October 2008, 01:18 PM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
MIIB
Nice design,
It looks like a combination of Hafler Transnova circuit along with Folded Cascode loaded VAS.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 14th October 2008, 01:25 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
Yes, you should be able to remove one driver stage.
I think the test results would not be so much bad.
I would start with try this:
- Remove Q13, Q11
- Replace Q18, Q19 with MJE15030, MJE15031
DC-Coupled feedback. Quite alright!
When we have JFET pair as input, we have almost no input bias current.
When using BJT, it is these very small currents, that create a different voltage drop
across feedback resistors(R45//R2) vs. Input resistor (R9).
Say we have a bipolar input pair. Into BASE of each transistor runs 1 uA.
R9 = 47000 ohm = voltage across R9 = 47000 x 0.000001 uA = 47 milliVolt
R45 // R2, paralleled 2000//50 gives combined resistance = 48.78 Ohm
Voltage across this resistance = 49 Ohm x 1 uA = 0.049 mV
The differential input pair will amplify (x40) the difference:
40 x [0.047 V - 0.000049 V] = 1.878 Volt DC-Offset at output.
With a blocking capacitor for R2 (50 Ohm) the resistance difference (for DC-current) would be 47 kohm vs. 2 kohm, which is smaller, but still too much (45000 ohm x 1 uA).
But if you would use R45 = 47 kohm, there would be no difference for the resistance bias current would see, and very little voltage difference at BASES of input pair.
And so not much DC-offset at output.
When using JFET input pair we have almost no input bias current.
And so we get no voltage drop across bias resistors, and no offset from this.
But we can get offset because the JFET input pair has different Volt Gate-Source.
So we may have to run these two FET with different current in each transistor. We balance current so that Vgs will be equal = no offset.
I see you may have used R4 for this current balancing in the input pair.
With real JFETs you may have to make R3(270ohm) and R4(262.4ohm) even more different.
lineup
Old 15th October 2008, 12:07 AM   #5
homemodder's Avatar
Lineup, I think one could rather remove Q6 and Q7. The output is a cfp driver EF, its one of the best output stages performance wise. Big improvementt on standard EF. It has very high input impedance and I think it could be driven by Q4 and Q5 alone.
I did something similar a while back, just cant find my sims between all the thousands of files I have, which yielded quite good performance. Ill try and find it. By similation one could tell which works best.
Old 15th October 2008, 01:41 AM   #6
lineup's Avatar
Yes, homemodder
Removing Q6 and Q7 is an option to try out.
Of course the ~ 1 mA from Q4 and Q5 may be a bit too small for the need of the diode string. (input pair 3 mA/each)
Currently there is ~12 mA through diodes. Set by CCS transistor Q7.
Trying my option first, would not change anything for conditions of the Bias setting diodes.
Another thing is some Stability Compensation capacitance.
If you find that you need this, one way to try is to add C1 like in my JFET Hifi Opamp.
This same way is used in Hi-Fi op-amp AD797.
( Topic: New JFET Hifi Op-Amp - by lineup )
The value needed to ensure good stability may be in the range: 22pF - 220pF
See attachment = C1
lineup
Old 15th October 2008, 09:26 AM   #7
Lineup
thanks for the advice om the outputstage...
I'll try to manke both version in my sims,,. i already did your first suggestion.. Turned out quite good.. But still i have a hunch that it won't sound as solid as the version with predrivers..
Also thanks for the hint on HF-compensation.. nice way to implement it..
michael
Old 15th October 2008, 10:45 AM   #8
traderbam's Avatar
Hi Michael. Unusual design. Would you elaborate on your choices?
Test. Without referring to your simulation, what do you think determines the feedback loop's unity gain frequency?
Brian
Old 15th October 2008, 11:55 AM   #9
This is basically en elboration on the Ad opamp discribed by lineup..but with differnt transistors and differetn current sources..
I saw that the design holds a unique dirtortion distribution alongwith the fact that i was possible to put cascodes so it could scale and grow into a poweramp..
I have built one with linear mosfets in the output... it had the most natural mids and high, but lacked the absolute punch in the base... as with most mosfet designs...
So now its fittet with a bipolar output design. Hope this will add the extra dimension.. and bottom end drive that is a must..!
Old 16th October 2008, 07:55 AM   #10
I have decided to try to remove the output buffer on the voltage amplifer and then integratre the diode bias spreader into the second summing stage...
I'll then have to change the transistors into a more ressiliant type and ajust so that more current is available through the diodestring.
This is possible due to the high input impedance of the outputstage
I'll return with schematics and sim results...
Power amp design? 6502dude Solid State 4 20th January 2006 09:02 AM
trying to design a power amp rx7speed Instruments and Amps 4 27th November 2004 11:41 PM
My X-Power amp design blu_line Solid State 3 1st February 2004 12:58 PM
searching for an power amp design @fundum Solid State 21 14th October 2003 11:47 PM
Page generated in 0.12439 seconds (85.86% PHP - 14.14% MySQL) with 11 queries
