Old 14th October 2008, 03:09 AM   #1
puska is offline puska  Canada
Default Quad 33 Please help!!!
Hi, I want to use Quad 33 as a Phono amplifier, and connect it to AUX of my integrated tube amp. Is it possible and how to do it. Thanks.
Old 14th October 2008, 12:04 PM   #2
sreten is online now sreten  United Kingdom
Yes it is possible, very straightforward, what is the problem ?
/sreten.
Old 14th October 2008, 01:12 PM   #3
BEAR-K is offline BEAR-K  Canada
Default Quad 33 phono
Hi:
Simply connect the record output leads to the aux input of the receiver.
Old 14th October 2008, 02:26 PM   #4
Thank you. I know that, but how to make cables din to rca? Thanks.
Old 14th October 2008, 09:00 PM   #5
get a din to rca M or F cable, if you want to swap over on the quad
and get rid of the din sockets for some nice gold Neutriks
have a look at the link! or take the cover off and trace the wires!
http://en.wikipedia.org/wiki/DIN_connector
Old 14th October 2008, 09:38 PM   #6
Thanks.
Old 15th October 2008, 07:38 AM   #7
burbeck is offline burbeck  United Kingdom
hi
the din plugs used are 4 pin types found here
http://britaudio.com/Parts.html
make a screened lead up with phono plugs to suit, the connections for the din plug are printed on the back of the 33
regards
bob
Old 15th October 2008, 11:31 AM   #8
Your original question was how do I do that?, not how do I make the cables. The Source or Radio Shack or local computer stores, even Canadian Tire! all sell the 5 pin d.i.n. to 4 rca cables that you require, these are entry level quality of course. I make up adaptor cables such as these,(I service Quad equipment ), using
as high quality parts as you desire.
Old 15th October 2008, 12:56 PM   #9
hi
yes that would be fine but the plug is not a 5 pin din, its a 4 pin.
please read my previous post
regards
bob
Old 15th October 2008, 01:29 PM   #10
hi
my mistake it is the output that has 4pin din, the tape in/out is 5pin din so bear is absolutly correct on this
regards
bob
Zen Quad 22 johnm Tubes / Valves 0 13th June 2008 03:21 PM
pcb for quad 405 kanjumi Solid State 6 3rd April 2006 05:03 PM
A new Quad ESL?? Audiofool Planars & Exotics 12 17th November 2005 10:00 AM
quad 909 dj_maxxro Solid State 0 4th October 2005 04:11 AM
Page generated in 0.09156 seconds (74.03% PHP - 25.97% MySQL) with 11 queries
