need echo circuit schematic does not have an ic in it
Old 13th October 2008, 10:38 AM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default need echo circuit schematic does not have an ic in it
need echo circuit schematic does not have an ic in it .is it possible
build an echo circuit that does not have an intergrated circuit or chip in in it iam not talking about tube echo unit
just wondering realy like to hear idea's
Old 13th October 2008, 11:06 AM   #2
acid_k2 is offline acid_k2  Italy
You can use a tape delay...
If you don't want tubes, use transistors for it...
Old 13th October 2008, 01:29 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
use a length of garden hose with a pair of transducers on each end
Old 13th October 2008, 02:17 PM   #4
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi!
Use, endless tape echo!
For mechanics the best mehanism is 8 track player from last century!!!!!!
Regards zeoN_Rider
Old 13th October 2008, 02:56 PM   #5
wg_ski is offline wg_ski  United States
Spring-loaded reverb tank. Parts Express has some in their latest flyer - about $20. It will take a single transistor to drive, and one to receive.
Old 13th October 2008, 02:59 PM   #6
stoN_Cold's Avatar
Default Hi!
Is not the same Echo VS Spring-loaded reverb!
Regards zeoN_Rider
Old 13th October 2008, 03:43 PM   #7
Yes... at 340m/s, you need 68 meters of garden hose for 0.2 sec. delay...
with some valves you could also have a great variable delay echo...
Old 14th October 2008, 12:17 PM   #8
Limhes is offline Limhes  Orkney Islands
Could you elaborate on this?
Old 14th October 2008, 04:50 PM   #9
it's a joke....
schematic attached...
Old 14th October 2008, 06:15 PM   #10
Steerpike is offline Steerpike
Steerpike's Avatar
How about a 1024-stage BBD using tubes?
More seriously though, many studios used to use 'plate echo' devices - which have quite an OK 'sound', but they take up a LOT of space.
Essentially what you need is a large sheet of thin sheet metal - like 6x6 feet.
I'd agree, tape is the easiers & cheapest. Cassette not easy to modify, but an old 3-head reel-to-reel is a pretty much ready made echo unit.
need echo circuit schematic does not have an ic in itHide this!Advertise here!
schematic for an optical to SPDIF (coax) circuit jarthel Digital Line Level 14 7th September 2016 04:43 AM
Schematic download problems at www.audio-circuit.dk Jan Dupont Everything Else 22 27th June 2013 07:15 PM
audio-circuit.dk schematic downloads has been blocked Jan Dupont Everything Else 19 14th October 2008 03:32 PM
Looking for schematic of CDM12 circuit board Peter Daniel Digital Source 5 8th April 2003 01:24 AM
need soft start circuit schematic supernet Everything Else 6 30th March 2002 01:31 AM
