Old 12th October 2008, 12:51 AM   #1
Default Ev 7300a
HI GUYS, MY CHURCH OWNS 7 EV7300A POWER AMPS.
ALL AMPS SAME AGE AS OF A WEEK AGO WEVE GOT ONE THAT BLOWS FUSE THE INSTANT IT IS TURNED ON. IT DOSENT MATTER WHETHER IT IS HOOKED UP TO THE REST OF THE SYSTEM OR NOT. I KNOW THIS IS A BROAD
DISCRIPTION BUT WERE LIMITED ON MUSIC BUDGET.
CAN ANY ONE GIVE ME A START OR DIRECT ME TO FURTHER 411.
RESPECTFULLY
JOHN LANCASTER
drum_man@comcast.net
Old 12th October 2008, 12:55 AM   #2
Speakerholic
Cal Weldon's Avatar
Default Re: Ev 7300a
Hello John,
I have moved this to amplifiers as the other section is for troubleshooting problems with the site
May I
[i] RESPECTFULLY [/B]
request you not type in caps. It looks like you are yelling.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 12th October 2008, 12:57 AM   #3
ostripper's Avatar
Very broad, but it sounds like a blown output transistor
(most likely) or power supply problems.
good that the fuse blew instead of speakers/or fire.
Old 12th October 2008, 01:15 AM   #4
The 7300 was made about 20 years ago and was replaced in the early 90's with the 2600. It has 20 years under its belt and its probably time to consider replacing it along with the other six of them. It is probably suffering from several blown outputs as well as damaged drivers and possible power supply damage. This amp is also old enough to consider replacing its power supply caps as well as the other caps. Call a local professional sound contractor and have him assess your system to get it into the 20th century and replace your antique gear.
Old 12th October 2008, 02:30 AM   #5
ostripper's Avatar
I wished I lived near you , drum man, I'd recap/ upgrade
all 7 of these classic's for you..
If you do decide to upgrade , can I buy the broken one from you??
New thermal grease or silicone insulators
on all outputs/drivers, 100$ in new caps
(4x15000) -each amp.. good to go for 20+ more years..
Made in USA
Page generated in 0.06641 seconds (77.30% PHP - 22.70% MySQL) with 9 queries
