#21 |
Yes, this is possible.
To make 2 LM317 circuits. Identical. And then you stack them one on top of each other. One for the positive half and one for the negative half. One hook only: You have to use Transformer with 2 Separate windings! ( one with a common middlepoint for Ground, will not work ) So make sure you buy 2 x 12 Volt trafo. Or what voltage you will use.
lineup |
#22 |
#23 |
![]() The idea is like this. This is for higher current (LM338). For preamplifiers and currents max like 1 Ampere we use LM317. Websource: http://www.pedjarogic.com/gc/supplies.htm
lineup |
#24 |
I'm glad to see you guys hav e gone down the LM3xx route. These are great regulators and bes t of all their performace is good, consistent and they work every time.
#25 | |
Read the serie "using 3 pins regulators" on this website: http://www.acoustica.org.uk/ You can also find more reference on this forum doing a quick search.
Ben. |
#26 |
I might go slightly simpler since 1a per circuit is just overhead room.
I can go with different capacitors. You sure I want not low impedance feeing the JFETs? I could go with some BGs or FCs instead of FMs. |
#27 |
Low impedance caps are better suited for switching supplies where ripple is in Khz or even Mhz, not Hz.
#28 |
Yeah , just standard caps will do (high temp. maybe??)
derate them good (35v-50v), use multiple caps on each rail (better than 1 big one) you are good to go.
#29 |
I am going to put a .1ohm resistor between the capacitors and the output lead on the LM137T's and it will fix it.
| Hum - can't find an answer by searching the forum | Simpleton | Tubes / Valves | 26 | 1st October 2007 09:39 PM |
| Searching for 1M0880 REGULATOR | gaborbela | Parts | 5 | 21st July 2007 04:29 AM |
| Searching for good 16cm (6.5') fullrange Drivers ... | youyoung21147 | Full Range | 23 | 28th August 2005 04:23 PM |
| searching for GOOD spiders | bassdabob | Subwoofers | 20 | 21st April 2005 04:34 AM |
| Searching for a good TL project | wake rider | Multi-Way | 7 | 8th January 2002 06:57 AM |
| Page generated in 0.10243 seconds (76.12% PHP - 23.88% MySQL) with 11 queries |
