Here you have video i have made hours ago.... HRII rebuilt and listening the unit... the noises you will listen, while the video is reaching the end, are because of the MP3 output plug..contact... damn toy! http://www.youtube.com/watch?v=9uwMoAXTKX4 .................................................. .................................................. .. Had problems? Post them in this thread. .................................................. .................................................. .. Re visiting the HRII I am re assembling the unit, and i found that we can make several mistakes… and some of them will trigger a panic into some folks not to much experienced building amplifiers. While adjusting, it is important to have heatsinks installed into the output transistors and also into the drivers… thermal drift will made you unable to adjust, and you may lost your output…I have tested to see what happens. Be carefull if you gonna use wires to connect your vbe multiplier (the thermal sensor, the one adjusts the stand by current) or your output transistors… this starts oscilations…make it as short as possible. (less than 10 centimeters)… HRII transistors are high speed, this means it can oscilate into VHF frequencies. Do not connect your supply voltage without the protective resistances, those ones in series with your rails. Do not forget to run a ground wire from the amplifier board to the heatsink… output transistors must be insulated from the heatsink as also the thermal sensor (bias adjustment Tr.) To adjust, or to check your off set and bias, first produce a short circuit into the input terminals, install protective resistances, and It is a very good idea to install 47 ohms resistance into the speaker terminal, and to do that after you check the off set first time if not high the offset (bigger than 25 milivolts) then.install the output load (47 ohms) to avoid be fooled by unstabilities… the amplifer is not so distant from the threshold of oscilation, tuned this way, amplifiers use to produce a nice treble (non harshing one)… but, the price you pay is that you may have oscilations if you fail in something during the construction or installation. Measuring your stand by current, having your meter connected into the protective resistance extremes……. opening the short into the input and introducing your finger (finger-o-matic signal injector) into the live input, the mains noise will be listened if you have speaker..if not..your 47 ohms load will be hot. The voltage you will measure over the protective resistances must increase when you touch with your finger producing amplification…but when you release your finger, the current (voltage readed) must drop down to 400 to 800 milivolts over 10 ohms (for instance) If injecting signal with your finger, or other signal source, and them releasing your finger from the input terminal… if doing that you experience delay to reduce the current, ot if it stays then ground your heatsink, install speaker into the output and reduce power transistors wires lengthes, and thermal sensor wire length too also remove the condenser (if you have it) installed from colector to emitter into the heat sensor transistor, the bias adjustment unit. The amplifier was not hard to adjust, was linear the current increasing while I was turning the trimpot while adjusting bias.. the resistance i have between driver transistor emitters is 180 ohms…. Was stable, but I could force unstabilities doing errors, reason why I am publishing some comments, some tips and tricks. Into the input i am using bipolar 4.7 uF condenser…. In series with signal and connected to drivers base, the 470 ohms resistances were substituted by 100 ohms resistance…I am not using the treble booster..it is switched off, my speakers, the ones I have now a days, are flat (not to much unflat). Small details, can drive you mad if you are not skilled into amplifiers construction…you may feel sad and abandon your unit… having care with those details I am explaining you gonna be happy and dancing. Stand by current can go from 40 to 80 miliamperes (400 milivolts to 800 milivolts measured over 10 ohms protective series resistances)… 300 mA is what you gonna measure having not ground.. do not be scared..install ground and be happy… you gonna see your crazy current measured drops.
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#2 |
Attached, Carlos
#3 |
to the output units to goes cooked! Not so long... and you have a lot of current drift this way. regards, Carlos
#4 |
i have fixed the one, insulated, under the board... no trimpot... resitances fixed... 2K2 and 820 ohms. This is hot glue... it melts bellow 90 degrées... and my amplifiers never reach this temperature... this same glue is fixing my board into the heatsink. Will melt?... i don't think so. regards, Carlos
#5 |
you will have not problems alike to pick up signal entering the input or audio cables. Produce a short before adjust off set and bias. regards, Carlos
#6 |
Input shorted.... 47 ohms into the output... protective resistances in place. 6.5 milivolts...or... 0.0065V regards, Carlos
#7 |
do the same with drivers, and also do the same with the voltage amplifier, also into the differential and into the rail regulators. The voltage must be from 500 to 640 milivolts into the HRII. But, the best voltage is 575 milivolts.... higher goes to the Vas transistor and 700 milivolts goes to the rail regulators base to emitter voltage. This voltage is stable, as not drift or offset... and try to clean your probe point... i did it soldering to be sure...also i was observing thermal drift and VBE results.. studying the unit to perceive details to inform. regards, Carlos
#8 |
the NPN and PNP output VBEs. Observe the voltage measured over the protective resistances... this is sligtly different into the positive compared to the negative because into the positive side you have 10 miliamperes only to bias the zener diode you have into the input. This is divided by 10 ohms (if you use 10 ohms as protective of course) and will result into 60 miliamperes... the unit is fine from 40 to 80 miliamperes... and can operate with lower and higher than that without problems too... this is the suggested range. regards, Carlos
#9 |
you install the heatsink into the metalic case, the heatsink will be grounded because the metalic case goes to the ground..or.. at least, people use to pick the secondary central wire and attach it into the chassis. regards, Carlos
#10 |
Not a good idea to operate the amplifier this way...it is AB Class amplifier folks!
| S9 OB - Revisiting narrow baffles | gainphile | Multi-Way | 30 | 3rd June 2011 06:27 AM |
| HRII debug thread, post the problems you had here | destroyer X | Solid State | 13 | 7th August 2010 07:59 PM |
| Yay, revisiting my amp | Kilowatt | Solid State | 0 | 23rd December 2003 09:50 AM |
| Page generated in 0.14088 seconds (82.96% PHP - 17.04% MySQL) with 11 queries |
