Improved Diamond Buffer Design
Old 8th October 2008, 09:40 PM   #11
TimS is offline TimS  New Zealand
Originally posted by TzeYang
Circuit looks very cool to be honest (though with emitter resistors it'll be even better).
There's one thing I don't understand, which of the following is of higher Zi (input impedance):
1) Source sees two diodes.
2) Source sees the bases of the driver transistors (typical diamond buffer structure).
Though it is not obvious the 2 diodes are in series with the high impedance of the current sources.
The high impedance dominates the 2 components.
Cheers
Tim
Old 8th October 2008, 09:57 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Tim,
Those are $7.78 each in singles from Newark in Canada.
Probably well worth it considering the thermal matching and reduction this means from hand matching. Never mind over buying what you need to find matched transistors. This I know from experience.
A link I don't know if this will work.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 8th October 2008, 10:19 PM   #13
Originally posted by anatech
Hi Tim,
-Chris
Thanks Chris
But once you do the conversion to NZ dollars it starts to look expensive to me.
But you are right if i could get close to implementing my original designs their simulation looks like the proverbial wire with current gain and no global feedback.
Cheers
Tim
Old 9th October 2008, 02:42 AM   #14
anatech's Avatar
Hi Tim,
I'm the same way. I hate to part with a buck. It takes a while (years) to figure out that the more expensive part can both save money and increase performance.
I don't know if that holds in this case. Another option is available. Surface mount packages exist with matched NPN and PNP parts. That would give you a great front end. I haven't look those up yet, but I do know they exist. Cyrus uses them for example. I expect they should be less money.
-Chris
Old 9th October 2008, 04:38 AM   #15
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
I can vouch for those THAT arrays. I have used the 340 matched complementary and plan to use them in my next project (SOIC 14). I just spent $50 for 8 of them though. By far the most expensive part in the circuit but on a good note, you will need little or no degeneration with them if you use them for current mirrors. You get what you pay for. I'm using them for the amplifying transistors in my circuit since there are no mirrors in it.
All the trouble I've ever been in started out as fun......
Old 9th October 2008, 06:20 AM   #16
Hi Tim,
-Chris
Originally posted by CBS240
Hi
Well you guys are convincing me.
So a question for you, how would you split the THAT arrays up?
Eg would you use a whole THAT 320 for the top current mirror and a THAT 300 for the bottom or would you split 2 THAT 340 arrays between the top and bottom current mirrors? Or would you do something else.
The first idea would give me an easier layout but the second idea would mean the upper and lower current mirrors would be closer matched.
And for the input section my first thought would be to have a THAT 340 on the top and the bottom, but then maybe splitting the arrays would give a better match.
What do you guys think?
Cheers
Tim
Old 9th October 2008, 04:36 PM   #17
anatech's Avatar
Hi Tim,
Without having read the data sheet, I'll offer you some general ideas.
Keep in mind what sections of your schematic that should be in thermal contact. Think of which parts should not be in thermal contact.
Watch your maximum voltage between pins or sections. This is probably high since they are using oxide isolation in wells, but don't count on this.
If you consider the above points, a solution will suggest itself.
Hi CBS240,
I don't have any yet, but they are on my mind. I'm glad to hear they work out for you. These are also supposed to be very quiet, low noise.
-Chris
Old 10th October 2008, 02:41 AM   #18
CBS240's Avatar
Hi Tim
In the datasheet it states the matching is between devices of like polarity. So the 340 has 2 matched NPN and 2 matched PNP transistors. The NPN is not exactly matched to the PNP, but I don't see how that will effect your circuit. IMO, I like swap mirrors better than cascade mirrors. But youíre paying a lot more to have separate matched dies in one package. (That is the big advantage with these in that they are not monolithic.) Is it really necessary to have a compound mirror? for THAT price.....
IME, you want to use these at around 1 or 2mA, they perform nicely. They are fast and very low noise, at least in my circuit. I measure a current gain of about 85, which is close to the datasheet, but much less than the Hfe of a BC550. I don't think this is a big drawback considering all the other positive properties of these transistor arrays. A few more uA of base current? Big deal.
For best noise results don't leave the substrate floating.
I have also used D44 and D45. These are nice linear TO-220 BJTís up to about 4-5A. Fast with plenty of gain. But are they really needed to drive 32 Ohms at +/-15V? Or are these not the devices you are referencing?
Anyway good luck
My
Old 11th November 2008, 08:05 PM   #19
Aurelian is offline Aurelian  United States
Try using a sziklai pair in the output, distortion on the diamond buffer drops with high betas
Old 12th November 2008, 06:47 AM   #20
Hi Aurelian
Funny enough I have already done such a circuit and it works great.
I think the others who were on this topic would approve too because it has everything they were suggesting too and it achieves the distortion, bandwidth and load driving performance that I was after.
Improved Diamond Buffer DesignHide this!Advertise here!
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 02:06 PM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 04:55 PM
Diamond buffer peranders Solid State 45 16th November 2003 12:00 AM
