I am trying to do AC Sweep Analysis. Every time PSPICE gives me this error: "ERROR -- Invalid Value" What could be the reason? Thanks. |
#2 |
OK, I got it solved. Now, the problem is I need some experimental starting values for my capacitors for the COMMON SOURCE amp. Thanks. |
#3 |
C vs R-load gives the lower rolloff freq (-3dB)
For such I use: uF x kOhm The higher this value ( C x RL ), the lower Rolloff Frequency My target value is at least 47 uFkOhm. This gives -3dB at 3.38 Hz For 100 kOhm load, I this means 0.47uF (470nF). Formula: -3dB frequency = 1/[ 2pi x C x R ] ... where 2pi = 6.28 uFkOhm value = Frequency -3dB 10 = 15.9 Hz 22 = 7.23 Hz 47 = 3.38 Hz 100 = 1.59 Hz (if you would use 1uF for 100 kOhm load.
lineup |
#4 |
To match C2 = 470 nF (47 uFkOhm)
you will need make input cap C1 so that you get a value >= 47 uFkOhm Otherwise input rolloff will be limit of lower freq rolloff C1 sees: R1 // R2 (6k2 and 4k7) The combined load (=the input impedance) is: 1 [ (1/R1) + (1/R2) ] ... which give 2673 Ohm = 2k67 47/2.67 = 17.6 uF ... to give 47 uFkOhm So, C1 needs to be 18 uF or more, to match the output RC value
lineup |
#5 |
Thanks!
it makes a lot more sense now. ... |
| Marantz CD6000 "ERROR" messages - Help! | Wombat | Digital Source | 77 | 4th May 2010 11:43 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Marantz CD67mkII OSE "Radial error", doesn't read any disks | Sarion | Digital Source | 18 | 10th October 2006 03:15 AM |
| Marantz cd63mkIIKI "disk error" even by replacing transport and laser | hansv | Digital Source | 4 | 7th September 2004 03:53 PM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.08440 seconds (73.38% PHP - 26.62% MySQL) with 11 queries |
