(I've searched for information on this fault but haven't come up with anything concrete).
I've got an Audiolab 8000A which crackles for a short period following power-up when the volume control is used. I'm pretty sure it's not the pot, as it's fine after 30 seconds or so. The crackle is a bit disturbing (to me at least) as I suspect that something is on its way out.
Has anyone got any idea where to look? PSU? Dried out cap? dry joint? I'm thinking that perhaps there is some DC current on the pot which shouldn't be there - am I barkig up the wrong tree?
I've seen the circuit diagram posted on this site but as far as I can tell it doesn't show the volume control which I guess is prior to the power amp input.
I haven't got around to measuring the rails yet but I will do so, however as this fault seems only to occur during power up from cold, I think it may be hard to capture it as it happens in real time.
Dave.
Dave.
Thanks for your replies.
Thanks again chaps.
I agree although I'm not sure if it's because the pot is more scratchy than it should be and somehow as a cap charges up in the volume circuit it is more apparent or if it's something else. I guess it must be worth swapping out the pot anyway given that it wouldn't cost a fortune to do so.Richard C said:I suspect the noise must originate from the volume pot if it only happens when the pot is turned.
Not sure, I will have to check this later.Is the noise level constant regardless of whereabouts the pot position is when it's moved?
This is what I was thinking, but I'm, beginning to think that a pot change is the first thing to do. If it's still a problem then I'll look for an if'y cap.AndrewT said:just guessing but could an electrolytic be leaking badly when it is cold or freshly charging?
Thanks again chaps.
