Old 17th October 2009, 03:12 AM   #621
MJL21193's Avatar
Looks good to me!
patchwork_bom.pdf
Old 17th October 2009, 03:45 AM   #622
Hm, forgot to put the index numbers back in, and the note about the faston header is cut off
version 1.01 attached
Old 17th October 2009, 12:47 PM   #623
destroyer X's Avatar
Default I have mentioned your name into my "BiAmp release" video
YouTube - Audio amplifier test - Dx TriAmp
If you dislike that, then just let me know and i will remove your codename (Mjl21193) from the video.
I was saying good things about your amplifier.... i was just fair..do not need to thank me because of that.
- "To Ceasar what belongs to Ceasar..to the Lions what belongs to Lions"
Yeah... the recording resulted awfull (will make another one)...maybe you will dislike your name there because of that.
ahahahahah!
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 17th October 2009, 05:22 PM   #624
MJL21193's Avatar
No problem Carlos.
You are hooked on the fun stuff now - a great reason to build more amps
Old 18th October 2009, 07:09 AM   #625
Do you have any specs/graphs for this amp besides harmonic distortion and PSRR? What's the max power at 8/4/2 ohms? Maximum rail voltage? Maximum current? How close can the output voltage swing toward the rail voltage?
Old 18th October 2009, 02:35 PM   #626
MJL21193's Avatar
There are some full power tests further back in this thread (I think). It's in excess of 140 watts into 8 ohms. Running it on a 4 ohm load is fine but make sure there is a good heatsink. 2 ohms is NOT recommended.
The max rail voltage for this (indeed, the voltage it was designed for) is +/-56VDC. To use a lower rail voltage would require changing the frontend cascode voltage divider (specifically R4), R11 to adjust current thru the VAS and R27 to adjust the current thru the frontend. Gain would need to be adjusted also - R26.
Old 18th October 2009, 07:56 PM   #627
What happens when you hook up a 2 ohm load?
Old 18th October 2009, 09:45 PM   #628
ostripper's Avatar
[QUOTE]What happens when you hook up a 2 ohm load?/QUOTE]
Seriously , if the amp is properly fused , you will just blow them , not the outputs. (I did this).
OS
Old 18th October 2009, 10:02 PM   #629
MJL21193's Avatar
The current capacity of the amp would be exceeded and the outputs would fail.
Is a 2 ohm load a serious option? This was initially designed for an eight ohm load but will do 4 ohms fine. For a 2 ohm load, rail voltage would need to be drastically reduced.
EDIT: Sorry OS, we posted together.
Old 18th October 2009, 10:27 PM   #630
So what is the current capacity, then? Is there no overcurrent protection?
The rails will be fused for each channel, yes.
EDIT: I assume that fast-blow fuses are preferred. What value should they be?
Need circuit board layout for STK4142II plaese steve101 Chip Amps 1 2nd August 2005 09:35 AM
Page generated in 0.10283 seconds (74.91% PHP - 25.09% MySQL) with 11 queries
