Old 1st March 2009, 08:15 PM   #501
your sound card shows a significant 3rd harmonic at 180Hz and another at the 9th.
Why does your amp show hum and buzz all the way through the spectrum?
Is this a test set up artifact or is it coming out of the amplifier?
regards Andrew T.
Old 1st March 2009, 09:06 PM   #502
MJL21193's Avatar
Hi Andrew,
The soundcard noise is shown below. This is the soundcard itself. Everything is lower than -100db.
The hum or buzz you refer to may be some interference - the DCX2496 is still connected to the remaining channels of the amp and powered, the connection cable is a 2 metre piece of unshielded telephone cable. The amps are very quiet, so no discernible hum or buzz.
I could do everything all neat and scientific, but the picture is clear enough - the amps are performing as predicted.
Compare it to the recent tests of my finished K10A - the magnitude of the hum and buzz is much stronger in that one, yet it is very silent. These peaks are way down.
Old 1st March 2009, 09:25 PM   #503
are you able to measure the output noise (with shorted input) of both these amplifiers?
I get the impression from your graphs that it is >>0.05mVac
regards Andrew T.
Old 1st March 2009, 10:21 PM   #504
MJL21193's Avatar
I'm too lazy to connect to my scope and I don't have a millivolt meter, but here's what I did - I recorded the output of an amp with it's input shorted. The result is attached and backs up the RMAA result. I used the same telephone cable attenuator rig as before (I need to make something better).
This doesn't show the voltage magnitude but in the next post I will attach a sound clip of this "noise".
Old 1st March 2009, 10:39 PM   #505
MJL21193's Avatar
Restrictions on the attachment size (100kb) makes for a short clip.
It's attached, a 3 second clip. You may need to listen with headphones.
Old 2nd March 2009, 12:07 AM   #506
GK is offline GK  Australia
"Very silent" was the intent, along with the simplest possible HV power supply.
Glen
Old 2nd March 2009, 12:17 AM   #507
Soundcard THD = 0.0019, therefore the amps THD = 0.0002% (0.0021 - 0.0019 = 0.0002). Very good!
THD's don't add and subtract that way.
Old 2nd March 2009, 12:25 AM   #508
MJL21193's Avatar
Yes, well I figured something was up, but it can't be a whole lot more. What is the actual calculation?
Old 2nd March 2009, 01:19 AM   #509
SQRT ( (dist1*dist1) + (dist2*dist2) )
So, 0.0009%, not 0.0002%
Glen
Old 2nd March 2009, 02:54 AM   #510
MJL21193's Avatar
Glen
Thanks Glen,
Another factoid to file
I hark back to the early pages of this thread to
this post from darkfenriz:
Going below say 0.02% THD at 20kHz in a design like this is hardy doable. I don't know where these 0.0000x% figures came from.
I guess we did the un-doable.
In any case, mission accomplished. The amps in the 6 channel case are on constantly - haven't been shut off in months. Totally quiet, stable and they sound sweet to boot.
Need circuit board layout for STK4142II plaese steve101 Chip Amps 1 2nd August 2005 10:35 AM
Page generated in 0.10243 seconds (83.99% PHP - 16.01% MySQL) with 11 queries
