#21 | |
And the simulation says.... This is with a 470uF cap across the emitters of the LTP. |
#22 |
A shot of the new 20kHz square wave. This at only about 5 watts output. The heatsink that I'm using is not big enough for the heat that would be produce at higher power with this signal.
#23 | ||
Thank you sir! The power supplies have been built for a couple months now. I thought I'd make sure I have those done before the amps and I wouldn't be tempted to rig up a temporary one to short out and explode. I'm going to go ahead and order the Fairchild 2SC5200/1943 for these. Even though I have many MJL's, I have many projects in my future - these will keep. Here's the above square wave magnified. This is through the input stage LP filter, BTW. |
#24 | ||
Well, in real life it does destabilize the amp as megajocke said . Oh well, one for that future symmetrical project... Did some more squarewave testing: 20kHz at relatively low output ~ 10 watts. This is 200kHz And 500kHzBoring, I know... Performance is very good now and I'll do a schematic update soon. |
#25 | |
A mistake on my part - that was more like 250kHz. Oh well. Schematic update. I have ordered the 2SC5200/1943 for the outputs. I have changed the drivers to the 2Sc2344/2SA1011 combo. I have changed the Vbe multiplier to a BD139 and changed the VAS to 2SA1381. A couple of other minor changes and that's it (for now). |
#26 |
For base stoppers I searched for 1/4 watt 2 ohm resistors on Digikey, but the minimum is something like 10 million, so I'm SOL.
Looking at the pic below of the (latest) prototype, I've shorted the base stoppers without a problem - very stable. I'll need to check again with the new outputs to see if it has the same stability. In the pic is my third board layout for this amp. I have a newer one that is much better but I haven't etched it yet. I thought I would work the bugs out on this board, then I'd could go straight to making 6 of the new ones. Along with the new outputs, I ordered some 2SA1381 for the VAS. In the prototype below. This is the "F" - hfe=160. I had a 2SA1011 in that position but changed it out for a 2SB1011 to test (I used the 2SA1011 for a driver - recycle). With the new temporary VAS, the drivers changed and the Vbe change, there is a notable difference in the performance, at least visually on the scope. Very stable, flat square waves (I'll show later) up to 100kHz, still look like square waves at 200kHz. Clipping is very clean, much more so now than before where the top half would "quiver". What can I attribute the improvement too? The new drivers? Most likely. The 2SB1011 is none to shabby for the VAS either, I used it on another project with good success. I'm looking forward to chance to have listen, maybe as early as this weekend. |
#27 |
I swear this is the last squarewave...
100kHz at about 5 watts (sine wave power output). Zobel resistor was getting pretty hot during these tests, done with +/-30 volts from my regulated supply. The original version of this amp could not do this. Yeah, this and $1.50 will get you a coffee.
#28 |
Nice MJL21193
After you have changed to 2sa1381 youll get even better performance. The 2sa1011 are excellent drivers, very good choice. 2sa1360 or 2sa1407 are aslo excellent Vas transistors. Change those 2n devices for something like 2sa970/2sc2240, 2sa992/2sc1845 or 2sa1016/2sc2362 and youll up performance some more. Attribute the improvement from the vas in your case, youve made a huge upgrade to your vas by using 2sb1011. Just compare the cob for instance. Since you need less capacitance to swamp the nonlinear capacitance accross the vas transistor, you could lower the vas cap too. Mainly sonic improvement. |
#29 |
I simulated your circuit in Microcap-9.
I'm getting ~0.1% THD at 20kHz with 1Vrms input. Mostly first order (40kHz) distortion. Any ideas? PS.: Sry for low-quality schematic |
#30 |
Are you sure the period of the signal, the length of the simulation, the length of the FFT window and all that stuff is setup right?
Try measuring distortion of the input signal to see if it is working right. |
| Need circuit board layout for STK4142II plaese | steve101 | Chip Amps | 1 | 2nd August 2005 09:35 AM |
| Page generated in 0.12786 seconds (79.22% PHP - 20.78% MySQL) with 11 queries |
