Mod tips wanted:Denon Power Amp
Old 28th September 2008, 08:51 AM   #1
clm811 is offline clm811  United States
clm811's Avatar
Question Mod tips wanted:Denon Power Amp
I recently acquired a second Denon POA2400 which needs replacement of a few parts. This is their "Optical Class-A" amp, rated 200W/8ohms, 350W/4ohms. My working unit is great, but I see that many parts are less than "audiophile-grade"...
I figure as long as I'm in there, maybe I could upgrade some critical parts in the signal path and power supply rails.
Anyone modded these amps, or have suggestions for changing those parts which would give the "most bang for the buck"?
-chas
First image is the voltage amplifier stage 1
Old 28th September 2008, 08:53 AM   #2
clm811's Avatar
...Or perhaps I should take the terrific (potted toroid)power transformer and build a new amp from scratch(any design recommended for +/-72v rails)?
Any guidance or opinions are welcome.
Thanks,
-chas
Next image is the current amp stage 2
Old 28th September 2008, 09:00 AM   #3
clm811's Avatar
Finally, the main(current) power supply.
The bridge rectifiers & large caps could be replaced(remember-bang for the buck)... any suggestions?
-chas
Old 28th September 2008, 09:07 AM   #4
clm811's Avatar
Lastly a photo of the amp itself, sans cover(showing power supply, boards and heatsinks).
-chas
Old 28th September 2008, 11:40 AM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by clm811
take the terrific power transformer and build a new amp
Leach amp boards : http://www.diyaudio.com/forums/attac...amp=1222149740
Such a power amp is one heck of a conversion amp, as are all late 80s Denon numbers, only requires a board transplant.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th September 2008, 07:39 PM   #6
clm811's Avatar
Default Where to find?
Thanks, Jacco! Looks great, BUT- Where can one obtain plans or purchase the boards/kit, etc.??
And I still welcome any mods/tips for this impressive amp.
-chas
Old 29th September 2008, 04:08 PM   #7
clm811's Avatar
Default Found it, Thanks!
On the Leach Amp WiKi.
Now if we can just get enough requests...
Old 1st October 2008, 05:22 AM   #8
clm811's Avatar
Default Parts upgrade suggestions?
The amp diagrams above show no caps in signal path, BUT there are resistors and bypass caps (as well as power supply caps and bridges(obvious candidates).
Which of these do you folks think are most inportant to upgrade in quality? Or should ALL parts be upgraded(too expensive and I'd probably go to another circuit).
TIA -chas
Old 24th October 2008, 10:55 PM   #9
clm811's Avatar
Default Decided to go another way
I've decided to repair/restore the POA2400 and sell it off to fund premium parts for my Rasmussen-Leach/clone amps...
Anyone want to buy a nice Denon POA2400?
-chas
Old 25th October 2008, 09:37 PM   #10
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would just replace the electrolytic capacitors.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Mod tips wanted:Denon Power AmpHide this!Advertise here!
DENON POA-6600A schematic wanted !! godzich Solid State 82 4th February 2017 03:39 PM
jX92 reflex design tips wanted keladrin Full Range 11 26th June 2006 02:49 PM
Help : Best way to flush mount speaker drivers and other router tips wanted?? Cacophonix Multi-Way 7 23rd April 2003 07:47 PM
Wanted: Aluminium Construction Tips Rarkov Everything Else 23 10th October 2002 02:45 AM
Copyright ©1999-2017 diyAudio
