Rotel RB-976 schematic
Disabled Account
Joined 2006
Breez, Rotel make use of the same amp configuration in different model amps, Im not familiar with the 976 but I suspect its the single differential input configuration. In that case you could try get hold of RA01 schematic which would be very similar. Your amp is a 6 channel one if I remember correctly. I have RA01 it if it can help, what is the problem you having??? If I remember correctly someone has posted a circuit diagram of the amp section here somewhere, search for posts by member called Stee. If the problem is with the preamp section Im afraid it wont help.
