HOW to modify .mod file?
Old 25th September 2008, 02:05 AM   #1
spice freak is offline spice freak  Canada
Default HOW to modify .mod file?
I have imported a model from IRF. it is a MOSFET. I used it in my schematic. Now I want to do some modifications to change the name attributes from 1 2 3 to the actual Drain Gate Source. How should I do that so that can make sure I haven't corrupted the file completely. The reason i am saying this is that i read somewhere that i should not change the names attributes for a part on Capture since this stuff is related to the model file.
please help me with this issue.
thanks
Old 26th September 2008, 06:20 PM   #2
Default Re: HOW to modify .mod file? - Clarification!!!
hi, i have posted this thread a couple of days ago and unfortunately it seems nobody has been able to give an answer. so, i was thinking it might need more clarification. please let me know if this is the case, or otherwise at least give me directions. thanks.
Old 26th September 2008, 10:29 PM   #3
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Hi spice freak,
If your intention is to spice some of your circuits, you can copy/paste your model/subcircuit file in any text editor and change whatever you need to, just renamed it (eg. IRF610 to IRF610x, so you can still have original subcircuit file) and import to your spice subcircuit files.
Non mai abbastanza...
Old 27th September 2008, 02:11 PM   #4
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
i regularly paste .mod files into LTSpice's standard.bjt and standard.mos files. or you can include the command ".model irf610.mod".
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 28th September 2008, 03:52 AM   #5
thanks.
what i meant is that, i don't know under what conditions i can change specific parts of a MOSFET for instance. Example: that suppose i have the model for a MOSFET. this text file, contains the parameters and syntax that comes from the simplified model of that device. now i might not be familiar with the model for a complicated IC. how should i change it? shouldn't i know how the model has been approximated?
thanks...
Old 28th September 2008, 05:23 PM   #6
you should know 1) how a model has been generated, and 2) what the mathematical relationships between the parameters are. otherwise you could make what seems to be a simple change to a parameter and get impossible results in a simulation (such as a simple amp with only a positive supply giving outputs that go negative).
HOW to modify .mod file?Hide this!Advertise here!
pdr or zma file for Neo3 arc2v Multi-Way 5 13th July 2010 09:52 AM
.slb file (translated library file)...! spice freak Solid State 0 28th October 2008 04:20 PM
File Uploader - php script with file validation lineup The Lounge 5 11th February 2007 10:09 AM
Help I need a file!!!! lawbadman Everything Else 9 8th October 2006 07:33 PM
