I have a boom box which I hacked to use full range speakers.
The 3 watts output sounds great from the older Sharp box. But the cd player has begun to skip and one of the tape decks has been out for ages but both AM and FM work. All I know about electronics is a slight ability to solder wires. Can a boom box accept the signal from the AC'7 jacks of my computer motherboard? I would want to be able to select PC in place of CD on the front switch of the Sharp. This can be done with AUX on my Yamaha RP U100. Can a set of jacks be installed on the boom box to go to the sound card on the motherboard? |
#2 |
I think you mean you want to input a line-level source? Probably via a stereo mini-jack, such as those in ipods?
You need to locate where the line level signals are inside the machine, and re-route with one (stereo) or two cables to a stereo mini jack. Signal ground, left channel and right channel needs routing. I assume you can live without the built in CD player, for example? If you are lucky it will be obvious looking at cables between the CD-player module and the source select / amp board, which things are what. I.e. with printing at the connectors. If you are unlucky it's all one big board. |
| mini boom box | M3G4 | Class D | 3 | 18th January 2007 12:51 PM |
| NSB portable boom box help | mazeroth | Multi-Way | 0 | 30th August 2005 05:04 AM |
| Kenwood KAC 820 Amp went Boom! | sidskiba | Car Audio | 8 | 3rd December 2004 05:58 AM |
| Bridging AMP causes BOOM (help please) | styxx | Car Audio | 4 | 13th January 2004 04:30 AM |
| R/Boom correction | timolien | Multi-Way | 1 | 7th July 2003 02:38 PM |
| Page generated in 0.13861 seconds (41.65% PHP - 58.35% MySQL) with 10 queries |
