we had extensive talks and posts about zobel networks ....there is one question that might sound silly but you never know
does it make any diference in a zobel network if the arengement is inductor and then capacitor and resistor to ground ..... will it make an change if its inductor resistor and capacitor to ground ????? does it make any diference which of the parts of the zobel is first attached to ground either the resistor or the capacitor ???? can it work visa versa ????? i think yes but on the other hand there might be reasons i dont know thanks
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
Does not make much difference,
if the output inductor comes before the Zobel or after. And if the cap or resistor is next to ground does not matter, at all. This is for sure! ------- I have seen both ways to put inductor in many amplifiers. Can be interesting, though, to see what a Professor in Electronics use. As we all know, a real Professor is always 10 times more right than any www.diyaudio.com besserwisser You do not become Professor in Electronics at Georgia Institute of Technology School of Electrical and Computer Engineering only because some people are nice .... I think http://users.ece.gatech.edu/~mleach/lowtim/output.html http://users.ece.gatech.edu/~mleach/lowtim/
lineup |
#3 | |
This is Professor Leach comment to the bove output stage
of his amplifier. One pratical thing with R50 C25 after the inductor is that they can be put across the amplifier output terminals (Speaker OUT). Leach have had bad experiences with putting these 2 components, The Zobel, on the PCB. Zobel is an equalization filter for flatten the impedance curve for the LOAD. This makes sense to me. To put it more close the LOAD, than close to the amplifier feedback point. Quote:
lineup |
#4 |
Lineup, the question was related if C or R should go to the ground!
My answer is that it makes no difference. Anyway I've to clash with Prof. Leach, 'cause the L//R must be after R-C. P.S.: Sakis, would you please ask more collected? |
#5 |
Did it Himself
One might question why Leach was allowing dirty Zobel currents to flow in signal leads.
Self has a completely opposite recommendation and one that I agree with, that the Zobel is to provide load and low impedance to pickup, at RF, to the output stage. Therefore it should be on the PCB as any inductance due to wires or traces will spoil it's effectiveness. You should have dirty ground for the Zobel and decoupling capacitors and a clean ground for the signal and feedback network. These two should return to the power ground star by their own wire. To answer Sakis, in a series connection it does not matter in which order components go. In accordance with the recommendation by Self, the Zobel should go before the output inductor, as the output inductor is to just protect against highly capacitive loads from crossovers and speaker cables.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
I would ground the capacitor, when I think about parasitic impedances.
#7 |
diy audio ..... even a silly question can bring so many opinions from so many people
thank you all very much my regards to PMA and LINE UP ..... my favourites !!!!
#8 |
You are very correct, Lineup , the Zobel/ inductor order is NOT
critical Being a perfectionist, one has to consider that the zobel's true function is to protect the amps output from too inductive a reactance (loudspeaker). Knowing this, one could speculate the best place for it is RIGHT at the output. The output inductor's job is block the effect of capacitance FROM the loudspeaker being introduced back to the amp. Both effect's as mentioned above will affect the NFB loop and cause various instabilities if left unchecked. Another aspect of the zobel I found interesting is where to "dump" the HF "garbage" that it filters out. Most DIY designs I've seen couple the zobel right to the PC board ground injecting this undesirable noise directly to the amp. In my designs I keep the zobel network ground separate by connecting it directly to the main chassis star ground which results in a much "cleaner" board/amp ground. In commercial amps I've seen all 3 implementations . (including my separated zobel scheme.) Like in the prof. leach design, the extra damping resistor in parallel with the output inductor reduces resonance (ringing) at the output. OS |
#9 | |
Any bypass capacitor and filter cap attached to ground
will inject Current spikes into GND. Where is Smaller caps, often smaller current. Big caps often big Currents. AC signal currents can not just dissapear. And ground rails are often transporting this to power supply. Ground rails have some resistance, inductance. No matter what geometry / size of copper. Copper has got resistance per volume & length. Current x [Resistance+Inductance] = Voltage. What we have done is SCREWING UP the 0-Volt ZERO Reference. And if 0 is +0.1 then follows that +2 is no longer 2 but +2.1. All other values are dependent on ZERO Reference. And if REF is changed, all other values are changed. Make this experiment. Quote:
We use often two 100 nF very close to chip V+ V- pins. Where we put the 'ground legs' of those 2 caps can sometimes make a BIG difference. This is why sometimes can be better to put only 1 capacitor. From Opamp V+ pin to V- pin. This way we avoid current injection at high frequency into the GND. My Lineup Bottomline: .. There is nothing more important in one AC Amplifier than to have a clean ZERO AC 0-volt Reference. Star Grounding is one good way, to try to achieve this. Note .. that ZERO DC Ref .. is not necessarily same as ZERO AC Ref. Many times DC Ref is not abolute zero. But AC Ref should always be as close to 0.000 Volt, as possible.
lineup |
#10 | |
| zobel question? | fazman | Multi-Way | 2 | 18th December 2005 04:11 AM |
| Zobel Question | Soulwax | Multi-Way | 2 | 2nd May 2005 05:21 PM |
| Zobel Question | poeee | Chip Amps | 2 | 5th January 2005 05:29 PM |
| zobel question | soundNERD | Chip Amps | 17 | 10th November 2004 07:05 AM |
| Zobel question | soundNERD | Chip Amps | 12 | 29th March 2004 11:57 AM |
| Page generated in 0.15908 seconds (72.38% PHP - 27.62% MySQL) with 10 queries |
