Hello and thankyou for looking i am in need of some help with this amplifier....
I can email the service manual which is a meg size approx in pdf Started to fix left channel as it was dead right channel was good.... Took output fets out they were shorted(irfp240) Got new ones replaced pre drivers with a close equivalent ,checked resistors signal diodes the norm...Put new fets in ... Turned on no blown fuses this time but sound is very quiet and very distorted...... While i was checking over on the left channel nothing leaped out getting 3.9 mv bias.... Then the right channel blew AAAAAAAAAAAAAAHHHHHHHHHHHHH was not even testing it took fets out of right channel and what a surprise both shorted fuse replacement time also..... Today i checked right channels predivers and removed the fets from other channel put them in and now doing same as other channel.. You can connect speakers up to the outputs and hear same distorted sound whether they are being driven by an output stage or not.............. Ihave jumped the relays so i have ruled them out ... I coonected up pre out to another amp both channnels fine Arcams volume,tone control all work normally so must be in the power amp stage............ Any ideas would be great....... Thankyou......
if you strip it for parts keep them for years as soon as you get rid you will want them ..................... |
#2 |
Is the same amp you keep starting new threads for
If you have the manual email me. No promises mind, the last Arcam I fixed here ended up a real marathon job. |
#3 |
Hi there thanks for reply Mooly could i please have an email address so i can attatch manual......Regards Steve
#4 |
Check your email
You can also click on my name (Mooly) to contact me. |
#5 |
Checking FET's isn't easy. Problem is the gate can charge up from static etc and give confusing readings, sometimes different every time you test them. The IRF types should read ( use the diode range on DVM ) as open circuit drain to source one way round and then reversing the meter leads it should read a bit like a diode the other way. They also should not read to the gate. You will have to read them out of circuit. Using FET's means the driver stages are pretty high impedance which can limit any further damage. |
#6 |
To be honest the FETs in the right channel were probably stressed too, and thats why they failed. Replace all of them - its not like theyre expensive. You are probably best replacing the drivers too.
Use a light bulb in series with the live wire to limit the current. |
#7 |
Not a good image
#8 |
Steve,
Depending how the FET's failed you need to do a basic check of all the low value resistors in the output stage. Anything under 1k including those 0.22 ohms. I know you spoke of replacing all the transistors, but first lets try and get some idea of what happened. Check also those zeners. Do any of the small transistors read faulty at all. Suitable replacements would include the 2N5551 and 2N5401 which were in stock last time I ordered at www.cpc.co.uk I can send you the data sheets for these as the pin outs are different. We have to start somewhere |
#9 |
Hi Mooly thankyou for your help so far i possess a towers international ,brilliant little book had it for about 15 years for tranny cross referencing,yeh i have got to twist 2 legs on those american 2n,s to make bce as they are cbe ....what is not shown in diagram is a
2sc2240 which sits in air above the the two ..0.22 ohm resistors..the base is connected to one side of those ..0.22 through a 10 ..ohm resistor...collector is connected to a diode not sure yet whether it is a signal or a zener and emitter connects to other side of those 0.22 ,,,looking at schematic it points to q12 (2sc2547) but q12 is elseware in board further near front end....Regards
#10 |
Hi jaycee thanks very the very valuable tip
| Arcam Delta 290 | lduarte1973 | Solid State | 2 | 28th February 2009 09:06 AM |
| Arcam Delta 70/70.2 | FibCouple | Digital Source | 2 | 12th January 2008 11:42 PM |
| mini compo cd playing section trouble | bbg9507 | Digital Source | 2 | 26th September 2006 08:17 PM |
| Delta 290 Arcam | mike salway | Solid State | 0 | 17th September 2005 03:03 PM |
| Arcam Delta 70.2 | Rotellian | Digital Source | 2 | 16th January 2004 10:33 PM |
| Page generated in 0.11943 seconds (76.33% PHP - 23.67% MySQL) with 11 queries |
