old transistor data
old transistor data
Old 22nd September 2008, 11:00 AM   #1
east electronics is offline east electronics  Greece
east electronics's Avatar
Default old transistor data
since we have some oldtimers in the forum i dare to post this pictures from recently salvaged transistors from a police stock house ....
interenet seems unable to provide information about that so any one knows about it is very welcome
thanks sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 22nd September 2008, 11:26 AM   #2
Mooly's Avatar
old transistor data
R0G02 Triac ?
Old 22nd September 2008, 11:30 AM   #3
Default cant be
down under there is huge marks E and B probably base and emmiter .... diode test from a multimeter doesnt measure like a triac but something like a npn but with other readings
Old 22nd September 2008, 11:33 AM   #4
Mooly's Avatar
old transistor data
Googled R0G02 and it comes up as obsolete Triac.
Try it and see.
Used to see a lot of odd parts years ago. Could the other one be a regulator perhaps.
Old 22nd September 2008, 11:36 AM   #5
Mooly's Avatar
old transistor data
Add to that, it was in things like TV chassis's that these odd numbers cropped up, you could never find the parts listed generally. Some TV's used Triac line output stages in a commutating type arrangement -- horendous things looking back.
Old 22nd September 2008, 11:40 AM   #6
Default true
i am with you but this do not justify the existance of tv triac in a police stock room
most items that i had from there in the past where RF related
so these could be parts of power supply related items ?
Old 22nd September 2008, 11:46 AM   #7
Mooly's Avatar
old transistor data
I know what I would do. Current limited PSU, connect it up, see what it does. Use a 1 k or something to dab the base and see what happens, does it conduct, does it latch.
Or non of the above
Same for the other. If your not sure if it's a reg bring the voltage up slowly and monitor the third "connection" and see if it levels off. Just keep trying every which way about.
Old 22nd September 2008, 11:52 AM   #8
Mooly's Avatar
old transistor data
Maybe it was a secret workshop, not a Police house.
Old 22nd September 2008, 01:02 PM   #9
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Transistor, not a triac.
Try a search for R-Zero-G-Zero-2.
There's also R0G03, R0G04, R0G05, etc, not all TO-3 package types, these semis are from the twilight zone period.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 22nd September 2008, 07:14 PM   #10
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
welcome to the wonderful world of OEM "house label" parts. you might (usually about a 50/50 chance) find a NTE or SK cross reference for it (a better chance is if you find an ECG or SK book from about 5 or 10 years after the date code on the device). there is a "shelf life" for cross referenced devices. there are many devices you can't find listings for anymore because they're obsolete for too long and are discontinued from even the cross references.
motorola did OEM parts for a lot of equipment manufacturers. usually they are a standard MOT part that has been given a "house number". MOT charges a few cents extra per device for relabeling parts like this, more if they do any selection for beta or other matching to a specification. RCA used to make oem parts too, often for their competitors in the TV market.... (think about that one for a minute...... )
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
old transistor dataHide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
Exactly titles of old transistor data books from NEC, SONY and Fujitsu (1975 - 1985) tiefbassuebertr Solid State 5 12th December 2011 05:31 PM
B&K ST-202 Data Chris Screven Solid State 1 7th April 2009 11:46 AM
Help! I need TRW(UTC) O35 DATA purer Tubes / Valves 0 26th February 2004 04:35 AM
Power Transistor data Sheets... where to find Harlan Parts 3 21st February 2004 03:03 PM
Copyright ©1999-2017 diyAudio
