Old 19th September 2008, 08:32 PM   #1
theAnonymous1's Avatar
Default LME49600/LME49740 Headphome Amp
I haven't seen any LME49600 headphone amps built around here so I figured I would post mine. It's the basic circuit from the datasheet with minor adjustments for parts on hand.
It sounds great with an absolutely pure black background. It's impossible to tell it's even on with the pot turned all the way down.
I built it small for portable battery powered use, but the idle current is ~47ma so I'm not so sure how good that's going to work out.
When I have the time I plan on building the regulators in the datasheet as well.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 19th September 2008, 09:47 PM   #2
Default Re: LME49600/LME49740 Headphome Amp
Headphome.
Old 19th September 2008, 10:47 PM   #3
jackinnj's Avatar
Maybe a motor-cycle lead acid cell
Did you bandwidth the LME49600? The LME497400 is a bit of a piggy when it comes to idle as well.
fwiw, I have my samples, just haven't got to play around with it yet.
Old 19th September 2008, 10:54 PM   #4
Yes, I connected the bandwidth pin to VEE because that's how the schematic has it. I tried lifting both the pins and the idle current went from ~47ma to ~35ma. Does a headphone amp really need 180MHz bandwidth anyway?
Old 19th September 2008, 11:40 PM   #5
jackinnj's Avatar
I think that some writers at Stereophile would find this a necessity.
Old 19th September 2008, 11:55 PM   #6
And the sight of the tantalum rail filtering caps on my board would probably make them lose their lunch.
Old 20th September 2008, 12:51 AM   #7
jackinnj's Avatar
I have sworn off SMT electrolytic caps, Al or whatever -- for DIY projects they are too much a nuisance.
Old 20th September 2008, 01:14 AM   #8
TzeYang is online now TzeYang  Malaysia
I think this amplifier is incredible.
How did you split the rails? Are those two huge ICs BUF634?
EDIT: Did you etch the board yourself? The boards looks very nice.
Old 20th September 2008, 02:12 AM   #9
Thank you.
I was using a +/-15v test supply I have; there isn't any rail splitting or buffered ground stuff happening on the board.
The two huge ICs are the LME49600 buffers. I think I read somewhere they are very close if not the same as BUF634.
I etched the board, but to be honest I think it turned out like c**p. I had already been up for 22hrs when I started on it and it shows. Then my dremel tools bearings decided to go bad making the drilling a PITA with little bits of carbide flying everywhere, so most of the holes are off center.
Oh well, I guess it's function not form that really matters, and it definitely functions.
Old 20th September 2008, 02:19 AM   #10
^Self-etched double layer boards tend to have HIGH failure rate. I'm surprised it turned out so reasonably well for your case.
I'm still too pussy to do it though. Actually I'm just too poor to afford failure.
Tl074, Opa4134, Lme49740 ztan Solid State 3 23rd June 2007 10:53 AM
WTB:LME49710 and LME49740 Ryssen Swap Meet 5 4th June 2007 08:38 PM
Page generated in 0.10694 seconds (72.64% PHP - 27.36% MySQL) with 11 queries
