I am running a pair of JBL 4343's, powered by a pair Phase Linear 700's bi-amped. One is a 700B (low amp), one is a fully complementary 700 Series II (mid's and hi's amp).
I like to cut the mid-hi amp gain (Series II) back about 3dB. The more I cut the gain, the more a 60Hz hum gets louder. It's loudest point is when the knobs are at about 12:00, then it decreases all the way down to full off. Is my problem caps that need to be replaced? (electrolytics?? filter caps??) Could the internal crossovers' caps be going due to age and heavy usage?? Or could it possibly be a ground problem with the active crossover that I'm using... Which by the way is based on the MOX design for the 4343's, with the help of Ian MacKenzie. Any help is greatly appreciated. Thanks, Craig |
#2 |
If you disconnect the input jacks is there still any hum? The 700's are quiet with no input attached. The setting of the pots shouldn't make any difference. Whenever I work on any P/L amp I always change the RCA's out as they get loose and intermittent.
The PS caps should have less than a few hundred millivolts of ripple at idle. At full load it will be slightly over 1 volt. |
#3 |
I disconnected both RCA inputs. The hum is still present. Both amps are running through a Topaz Isolation Transformer too.
What does this mean? Amp Caps? Thanks, Craig |
#4 |
Did you check the ripple? Why the xfmr?
#5 |
Power supply caps are a problem with this amp especially considering its age. Replace them.
#6 | |
If anyone can point me to some please do. |
#7 |
I'm not so sure that's true with some of the top-tier manufacturers, such as Vishay/Sprague (36DA & 36DX) and Nippon Chemi-Con (United Chemi-Con)(36DA). The latter of those two makes exceptionally well-built caps.
| Phase Linear 200 Series 2 | IrishboyM4 | Solid State | 23 | 28th May 2008 03:04 AM |
| Phase Linear 400 Series 2 Repair | rwagoner | Solid State | 50 | 1st September 2007 03:01 AM |
| Phase Linear 700B Series II -Right channel out- | Kyllswytch | Solid State | 22 | 28th March 2007 01:53 AM |
| Clair Bros Phase Linear 700B Series 11 | macka | Swap Meet | 3 | 24th January 2004 04:18 PM |
| Phase Linear 5100 Series Two Manual? | Netlist | Solid State | 0 | 1st August 2003 09:36 AM |
| Page generated in 0.11954 seconds (67.94% PHP - 32.06% MySQL) with 10 queries |
