Another issue,
I do found the volum potentiometer has a bit of noise on the left channel. I want to clean it, but don't want to de-solider it if possible. Will this spary solvent work? http://www.jaycar.co.nz/productView...eMax=&SUBCATID=
It says:
A blend of non- CFC solvents and RF contact treatment oil. Ideal for cleaning and lubricating non- arcing contacts and mechanisms. Can be used for cleaning & lubricating all types of contacts.Safe on most plastics.
Link: http://www.jaycar.co.nz/productView...d2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
You only want to clean so use the one without the lubricant.
NA1004 from Jaycar
http://www1.jaycar.com.au/productVi...d2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
or T3066 from Altronics
http://www.altronics.com.au/index.asp?area=item&id=T3066
I recently cleaned a pot on a A400X and used the first one listed.
NA1004 from Jaycar
