Pioneer A400X help. How to uninstall the input switch?
Old 18th September 2008, 05:10 AM   #1
Huchiz is offline Huchiz  New Zealand
Smile Pioneer A400X help. How to uninstall the input switch?
Hi, I'm new here, and my English is no good, please be nice to me.
I just bought a Pioneer A400X to pair my Warfedale Diamond 9.1. The A400X is in quite good condition, except the selection switch is little loose from the panel. I mean the turning knob is still very tightly secured to the switch, but as a whole, they are little loose from the panel. I'm sure it has no effect to the performance. But just feel not so good when using.
I would like to know how to detach the turning knob from the frong panel/turning switch? I cannot find a screw on the knob. Shall I just PULL IT HARD? Anyone knows?
Plus, I have a user manual of A400X, anyone needs information, just let me know. Cheers.
Old 18th September 2008, 08:48 AM   #2
reddish75 is offline reddish75  United Kingdom
hi mate, what you need to do is pull the knob off the switch which will revel a nut ,just tighten this and jobs done.
Old 18th September 2008, 03:01 PM   #3
Thanks, that was done.
Old 18th September 2008, 03:01 PM   #4
Another issue,
I don found the volum potentiometer has a bit of noise on the left channel. I want to clean it, but don't to de-solider it if possible. Will this spary solvent work? http://www.jaycar.co.nz/productView....Max=&SUBCATID=
Old 19th September 2008, 07:51 PM   #5
jkeny is offline jkeny  Ireland
Banned
Hi Guys,
Yes, Huchiz, that contact cleaner will work.
I need to replace my A400 vol pot & I believe it's the same as the 300 & 400X. Trying to find a replacement.
I see some ID markings on my pot but most are illegible - can you make out what's on yours?
They are ALPS pots & ID starts 02 & ends 063-A
Old 19th September 2008, 08:36 PM   #6
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
It's Pioneer part ACT1077 but that probably will not help a great deal. BTW, it's a linear pot 50K-B1X2 and uses resistors on the PCB to do the log taper.
I'm pulling my A400X out tomorrow to go on ebay so will see if I can see some Alps numbers on it.
No longer DIY active
Old 19th September 2008, 09:09 PM   #7
Banned
Thanks Rabbitz,
My guess was wrong then - the 300 pot is not the same as the 400 & 400X. Mine is 100K log pot, I believe (but I've been known to be wrong)
If you get a chance to spot the 400X's vol pot markings, that would be excellent
Edit: Jeez, I just looked up the price of this part here http://www.ued.net/catalog/cat_item_idx_2904.html
$38 is a joke, right?
Rabbitz, did you get the part no from a service manual? I only have the schematics for the A400!
Old 19th September 2008, 10:41 PM   #8
Hi guys,
That cleaner really works, it kills all the noise. lol
I will open the case again today to lookup the part marking, will post soon.
Old 20th September 2008, 12:47 PM   #9
rabbitz's Avatar
Had a look at the pot today and no more info than that shown on post #6 sorry. There's no Alps identifier on mine except for Alps Japan.
The marking detail came from the A400X service manual and I think there is a reference to it in the schematic.
Not only do these have 2 rows of 4 pins but they also have a leg out the back to ground the pot body as they are mounted on a plastic recess. If a pot is replaced, you have to be sure to ground the pot body.
Old 20th September 2008, 12:54 PM   #10
rabbitz's Avatar
$38 isn't a bad price as it would cost more to put a non standard pot in there and get it working.
Pioneer A400X help. How to uninstall the input switch?Hide this!Advertise here!
NEED HELP for Pioneer A400x mods MTO audio Solid State 6 21st January 2009 10:41 PM
Pioneer won't switch on (like dead) AudioAddicted Car Audio 21 14th February 2007 01:56 PM
uninstall mechanism to play self-recorded max29 Digital Source 0 25th December 2006 12:40 PM
Pioneer Switch Knobs bobzorunkle Parts 1 2nd November 2004 08:30 AM
Copyright ©1999-2017 diyAudio
