Old 17th September 2008, 03:41 PM   #1
PTSOUNDLAB's Avatar
Default Pioneer SA7800 stv2h diode
Hello,
I search 2 Sanken STV2H for an old Pioneer SA7800. Does somebody know where I can find these spare parts or know a good substitute.
I despair to find.
Thank you
Best Regards
Pascal
Old 17th September 2008, 08:41 PM   #2
PTSOUNDLAB's Avatar
the schematic
Old 17th September 2008, 09:35 PM   #3
destroyer X's Avatar
Default It seems almost any silicon diodes will fit.
This is only to produce a voltage reference.... also you have adjustments...so....not needed to use the same.... so... if the new diode reference voltage (the voltage that will appear when measuring into the leads) results sligtly different... the trimpots are there to compensate.
Other diode will work.... same work... it is alike Coke inside the bottle and Coke inside the glass...both are Coke....tastes Coke, smells Coke...because it is Coke!
Se parrait...parce que c'est le même chose.
C'a marche!... allons enfants de la eletronique!
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 17th September 2008, 09:55 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Pascal,
Did you break yours? If not, the bias control (VR5) is probably bad as well.
That part was discontinued many years ago. Look for those in scrap amps and receivers from the same time era as yours.
Now, for a new solution you would put together a VBE multiplier. This part is used as a temperature sensor to compensate the bias current. Using a pair of diodes is risky as they need to be mounted on the heat sink directly. The transistor in a VBE multiplier can mount in the same place with a small PCB.
A "VBE multiplier" is simply the standard type of bias control circuit that has been used in newer equipment. Look at some newer schematics and you'll see what I'm talking about.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 17th September 2008, 11:28 PM   #5
Default I see... this one may have a screw hole to be attached into the heatsink...
......so..... as a consequence, my single diodes substitution may not be a good idea.... to use my idea the diodes may need some kind of insulation (schrink tubing) and to be glued into the heatsink.
Thank you Anatech.
regards,
Carlos
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Pioneer SA-8500, diode equivalent munja Solid State 17 24th October 2005 05:43 PM
Page generated in 0.08971 seconds (65.93% PHP - 34.07% MySQL) with 10 queries
