Old 15th September 2008, 12:28 AM   #1
Default 3 Pin regulated supply VS zener based supply
Hello,
I have a little integrated amplifier with a zener based power supply for the op-amp based pre-amp section.
Would there be sonic benefits to replacing this with a regulated supply built with good quality 3-leg regulators?
I have searched and only found one thread that relates to this and nothing was definitive.
I would possibly build something like the Welborne Labs PS1 module.
Kevin
Old 15th September 2008, 03:23 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Kevin,
Many times performance will come down to how well the circuit is executed. A small modification to the existing circuit would really improve performance.
Replace the resistors feeding the zener diodes with constant current sources delivering around the same amount of current. You can bypass the regulated voltages with some low value capacitors, around 0.22 uF. You can play with the values. The bypass is intended to be in parallel with the existing electrolytic caps. May as well replace those electrolytic capacitors with new ones of the same capacitance value. A higher voltage is okay. Just make sure it fits the spot.
There is a fair amount of material available both here and on the web on constant current sources. Use your common sense when reading "white papers" and circuit descriptions. Some are nothing more than advertising hype.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 15th September 2008, 08:23 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
hi KevinLee
anatech gives some basic and good info
if you want to learn more
there is some good pages at www.tnt-audio.com
Diy & Tweaking > Solid State
General articles
http://www.tnt-audio.com/clinica/solidstate.html
* Crash course on solid state power supplies
o First chapter
o Second chapter
o Third chapter
* Crash course on voltage regulators
http://www.tnt-audio.com/clinica/reg..._noise1_e.html
o Part 1.1 - Introduction and methodology (Noise)
o Part 1.2 - Tests & plots
o Part 1.3 - Tests & plots
o Part 1.4 - Tests & plots (+ batteries!)
o Part 2.1 - Introduction and methodology (output impedance - LM 317)
o Part 2.2 - Methodology (output impedance - TL 431)
o Part 2.3 - Methodology (output impedance - Emitter follower)
o Part 2.4 - Methodology (output impedance - 2-transistor shunt)
o Part 3 - Ripple rejection
lineup
Old 15th September 2008, 02:40 PM   #4
lineup's Avatar
there are also very good articles
if you search with www.google.com
that can explain the basic different of
series regulation
vs.
shunt regulation
A good and easy way to do The Shunt Voltage regulation
for audio circuits,
is using the Adjustable Zener Shunt Diode called TL431
It will make 2.5 - 36 Volt, set by only 2 resistors.
http://focus.ti.com/lit/ds/symlink/tl431.pdf
TL431 comes in several different packages.
IC DIP type or TO92 type.
lineup
LT1085-based regulated 6.3v heater supply eranrund Tubes / Valves 10 30th December 2008 04:58 PM
Zener regulated power supply hags Power Supplies 3 8th October 2007 03:58 PM
High Current Power Supply 12v, with zener on base jacquesl Power Supplies 13 26th August 2007 05:30 PM
ono and zener regulated power supply patriz Pass Labs 5 22nd October 2004 12:34 PM
regulated supply for GC yuval Chip Amps 9 16th April 2004 09:06 AM
Page generated in 0.09132 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
