all Gain Stages AMP
all Gain Stages AMP
Old 14th September 2008, 11:33 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default all Gain Stages AMP
hello
see this new project with MPSA transistors
and Voltage gain also in final devices as IGBT
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 14th September 2008, 05:53 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
looks like it will work well
maybe even be very good
.. depends on your used transistors and current levels
2 resistors serve no good purpose:
those two at most far right = from POWER Transistors collectors.
The only thinkable purpose, that they may do,
is to reduce Max Output current = some protection.
Other wise these 2 resistorswill only make output stage
work more BAD
Lineup regars
lineup
Old 14th September 2008, 08:07 PM   #3
Stee's Avatar
Default hello
really at the moment i have tested FET parallel with IGBT
works very good
(k170 and J74 + GT20D101/201)
THE PROBLEM is found an equivalent circuit
because this TOSHIBA devices are hard to buy
all Gain Stages AMPHide this!Advertise here!
Modular Gain Stages for Tube Guitar Amp GravyBoat Instruments and Amps 10 31st March 2015 10:01 AM
volume between gain stages blindbrett Tubes / Valves 1 8th July 2008 02:22 PM
Cascading gain stages in a tube preamp dakotadave Tubes / Valves 4 25th January 2008 01:56 PM
