Hi
I am trying to find ways of improving the performances and scope of DC servos. In general, their function is very narrow and focused, but I would like to give the servoing amplifier a bigger role. In summary, I want to combine the accuracy, linearity and high open-loop gain of a precision amplifier with the power and bandwidth of a power amplifier. Nothing new, and a number of solutions have already been provided. But I want to implement it in a more general and convenient way, with some additional constraints. The picture shows a (non-working) example of what I try to achieve: U1 symbolizes the fast, low-accuracy power amp. U2 is the precision correction amplifier. It compares the output scaled by R4/R5, to the input signal, and corrects the input of U1 via R3. The HF part of the signal goes directly to U1 via the feedforward capacitor C3. Obviously, it doesn't work: C2 and C3 introduce two poles in the loop, resulting in a strong gain and phase variation in the middle of the band. The constraints: The summing point for LF and HF signals has to be the NI input of the power amp. The correction amplifier has to be fully isolated from the HF signals, both on the inputs and the output: this is the reason for C2 and C4. This is also the reason why it is not possible to introduce a lead resistor in series with C3 f.e. The role of U2 must strictly be limited to LF. Is there a clever way of achieving these objectives, without resorting to ultra-accurate matching, or much more complex circuits? |
#2 |
It sounds like you want to build a composite amp. Here's some basics:
http://focus.ti.com/lit/an/sboa002/sboa002.pdf I've successfully experimented something like this (not intended for high precision): http://www.diyaudio.com/forums/showt...04#post1528904 |
#3 | |
But often, like in your example, amplifiers making up the composite have similar frequency characteristics; simple summation techniques can therefore apply. When the frequency bands have to be separated, and the summation occurs upstream of the main amplifier, things become much more complicated, as I have shown in my example. This why I chose DC servo as a title, although it's much more radical than usual DC servos. |
#4 |
i used to be the final test and customer service tech for a company that used a DC servo in their power amp the trick was that the servo had a -3db point of 5hz, and was isolated from the audio feedback loop. it worked extremely well (so well, in fact, that in doing the DC offset adjustment, if you forgot to disconnect the servo, adjusting the offset pot did absolutely nothing except change the mix of even harmonics in the distortion residual).
your picture is missing most vertical lines, but i think i get the idea of what you're trying to do. you have the input to the servo tapping off from part of the audio feedback, and the lack of isolation between your AC and DC feedback loops is where your problem lies. i'll upload a copy of a servo i know works later, and you'll see what i mean.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#5 |
i do not use dc servos
and probably never will the normal dc feedback is enough for my amplifiers but not for some others amps, i suppose regards lineup
lineup |
#6 | ||
If the correction amplifier is one of the new, ultra-low distortion chips, it will contribute to the linearization of the lower part of the spectrum, which can be beneficial. Quote:
#7 |
It is easier to get high bandwidth low noise low distortion amp closing a GFB loop around stages with local feedback than the same loop around the same stages without local feedbacks. I once made an amp in class A+C with such approach, it was much better than any traditional AB class amp, both sonically and according to measurements. 3 negative feedbacks on AC, and one global on AC and DC.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#8 | |
Look up some old CRO service manuals. This is along the lines of how wide bandwidth, DC-coupled oscilloscope input amplifiers used to be made when IC opamps started to come into fashion. The the HF response of the opamp was deliberately rolled off at a transition frequency of at some kHz. The directly coupled output of the opamp was then summed with the output of a discrete, AC coupled amplifier for the higher frequencies, coming in with a comlementary high-pass response at the transition frequency for an overall summed flat response. I once copied the idea for a precision instrumentation thingle using an AD707 and a GHz fT discrete transistor array for the AC ampifier (can't remember the part # for the latter, but Farnell sells it). Cheers, Glen |
#9 | |
#10 | |
Well yeah, that's pretty much the idea. With a little component matching it is a relatively simple way to a uV-precision DC coupled amplifier, -3dB at several hundred MHz. Cheers, Glen |
| CDM-2 Servos - Static vs. Dynamic | amc184 | Digital Source | 0 | 28th April 2009 01:50 AM |
| cascaded servos | Onvinyl | Solid State | 0 | 6th June 2008 05:36 PM |
| CDM-1 servos (Marantz CD-12 aka Philips LLH1000) | tvdw | Digital Source | 9 | 14th April 2006 02:43 PM |
| Offset servos needed? | Tsanford | Chip Amps | 5 | 29th July 2004 09:50 PM |
| DC Servos - Why Are They Badly Regarded ? | mrfeedback | Solid State | 97 | 27th April 2004 03:16 PM |
| Page generated in 0.19256 seconds (64.15% PHP - 35.85% MySQL) with 11 queries |
