hi, not much to comment really Whether you use it for SPICE MODEL testing or Build Something like it for your REAL MOSFET tests. Gives Voltage GATE-SOURCE ( VGS ) for a specific DRAIN CURRENT ( ID ) And for both the NMOS and the PMOS transistor. Perfect for see approximately what values your transistors will have at an idle Current in your PUSH-PULL Output Stage. This setup used 5 Ampere and 20 Volt DRAIN-SOURCE. So this is something what these EXICON Lateral will have for VGS at 100 Watt per devices! Lineup
lineup |
#2 |
Hi Lineup,
honestly I don't see any benefit in a push-pull VGS-tester compared to the usual source-follower, would you enlighten me? What's the use of the nameless basis-collector caps? Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#3 |
of course,
the same can be done with bipolar BJT for get the HFE gain of output complementary Pairs and V b-e drop at different OOUTPUT currents i have a couple of those bipolar circuits, too to examine spice models when i design my amplifier ideas
lineup |
| split push-pull output stage | andrew_whitham | Tubes / Valves | 16 | 22nd March 2007 07:25 PM |
| series connection of filament in push pull output stage | nhuwar | Tubes / Valves | 42 | 10th February 2007 07:27 PM |
| 6BQ5 as a Push Pull Output Stage. | ppl | Tubes / Valves | 7 | 23rd December 2004 10:32 PM |
| Push Pull Output Stage Question | 316a | Tubes / Valves | 4 | 10th February 2003 02:04 AM |
| unity gain push pull output stage | ergo | Solid State | 11 | 6th January 2003 11:32 AM |
| Page generated in 0.06468 seconds (77.61% PHP - 22.39% MySQL) with 11 queries |
