xr2206 problems - Page 2 - diyAudio
Old 12th February 2013, 06:44 PM   #11
I made some generators using theese a lot of years ago.
They are relatively dependant of a GOOD layout, and as one already said: Poor output impedance. Let it have a good bufferamp, and You will be better off.
Sooner or later you end up with TANDBERG
Old 12th February 2013, 07:43 PM   #12
Hi Sakis
That glitch is inherent in in all simple 2206 sinewaves.
Elektor Function Generator generator from ~1980 had the same issues, even as a complete and well built instrument.
The problem is with switch and lead capacitance at pin 13 and the solution they used in a revised circuit, was to fit a very closely wired BS170 mosfet switching device. I hope you will know how to wire that up, because I can't recall all the details of what voltage was used.
EDIT: This might help: http://www.granta.g4axx.com/pdfs/Generator.pdf
Good luck and
Ian
Old 12th February 2013, 08:02 PM   #13
stoN_Cold's Avatar
XR2206 never able to give the correct forms.
Although with time to work.
Regards zeoN_Rider
Old 12th February 2013, 09:06 PM   #14
wahab is offline wahab  Algeria
This IC was meant for easy build of a basic functions generator ,
good for its waveforms versatility but average not to say mediocre
performances wise.
Old 12th February 2013, 09:31 PM   #15
Here you go, seeing that this is for visual aspects of audio, a video of an XR2206 generator should be just right. We expect you to at least match this one...
DIY XR2206 Function generator - YouTube
Ian
Old 12th February 2013, 10:07 PM   #16
bobodioulasso's Avatar
I got a clean 100khz square wave from a cmos tlc555 + totem pole.
Old 13th February 2013, 07:14 AM   #17
east electronics's Avatar
Topward 8110 is also based on xr2206 now this is a rel. cheap instrument of about 250 euro but its decent enough ( i own one )
so xr 2206 is fine we just need to know how to operate it it properly
Thanks Ian will look in to it and get back to you
kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th February 2013, 10:25 AM   #18
Though square waves are poor past 20khz compared to a TLC555 wired as a schmitt trigger astable oscillator.
I use XR2206 for sinus, and Schmitt trigger for square.
Old 13th February 2013, 10:35 AM   #19
Schmitt trigger TLC555
Old 13th February 2013, 02:27 PM   #20
Hengy is offline Hengy  Canada
This might be a very wrong answer.. someone else will have to confirm, or if you have the parts it wouldn't be hard to try.
A schmitt trigger on the output might give you 'sharper' output. A high-speed opamp in a buffer config will give a low impedance output.
I would recommend the 555 timer-based oscillator that bobodioulasso posted. Simple and effective.
Hengy
B&K 700 problems? ThSpeakerDude88 Tubes / Valves 12 14th March 2009 04:59 PM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
I have hum and DC-problems Progg70 Solid State 10 5th August 2007 05:01 AM
Copyright 1999-2017 diyAudio
