10-20 Watts Super Single Ended Class A
Old 9th September 2008, 05:38 PM   #1
umut1001 is offline umut1001  Europe
umut1001's Avatar
Default 10-20 Watts Super Single Ended Class A
hi..i built some single ended designs.i made this circuit and i can say its the best i have heard.and i have some questions...
1-)how we decide the max or best voltage supply value of single ended symmetrical class a amps?(for this amp with irfp240 transistors)
2-)i replaced irfp240 instead of irfp 150 in this circuit.mids and trebles increased and bass reduced..but i always see positive offset of 150mv..i can reduce it to 100mv only by playing trimpots..i can not reduce it anymore..which values of resistors should i change?
3-)what is the technical criterias of sound quality for transistors?
is it low input capacitance?or low Qg?
thanks
best regards
umit
Old 9th September 2008, 08:52 PM   #2
umut1001's Avatar
is there anybody here?thanks
Old 9th September 2008, 09:14 PM   #3
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
You don't want me to comment a diffpair...
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 9th September 2008, 09:27 PM   #4
umut1001's Avatar
i didnt understand..everyone can comment..here is another one..its 32watts rms..has lower distortion..someone says its one of the best
Old 9th September 2008, 09:39 PM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Adjusting R4 value you may reduce your off set to zero
try a combination... a fixed resistance plus a trimpot...then adjust and measure your offset.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 9th September 2008, 10:03 PM   #6
umut1001's Avatar
thanks i will try..i should change some resistors..there is sth wrong at this amp..
what about the 1. and 3 questions?
Old 10th September 2008, 10:10 AM   #7
R.I.P.
for irfp240 the maximum supply voltage is 240Vdc.
The ideal voltage will probably be less than this maximum.
regards Andrew T.
Old 10th September 2008, 10:16 AM   #8
umut1001's Avatar
hi andrew...there is not a single ended transistor amp works at 200v dc.i meant what is the max voltage value for se class a amps for only one pair of irfp240.whatever.and what about the question 3 ? thanks
Old 10th September 2008, 11:02 AM   #9
R.I.P.
...there is not a single ended transistor amp works at 200v dc.i meant what is the max voltage value for se class a amps for only one pair of irfp240....
I bet there is more than one.
regards Andrew T.
Old 10th September 2008, 11:06 AM   #10
umut1001's Avatar
i dont understand
10-20 Watts Super Single Ended Class AHide this!Advertise here!
Single ended amp from class A push-pull Wavebourn Tubes / Valves 2 12th October 2007 09:14 PM
5 watts single ended amp renjiish Solid State 23 22nd January 2005 12:45 AM
class A single ended darkfenriz Solid State 16 21st January 2005 07:22 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
