Old 9th September 2008, 04:56 PM   #1
destroyer X's Avatar
Default Yamaha RX V496 - i am needing the schematic
Can you please help?
A friend left the unit here and asked me to produce some examination.
It is not switching one... as soon as you switch on the protection relay enters.
I have removed the output emitter resistances to check if this will allow the unit to power on...and negative.
Well... the equipment is very complex, and i am lost looking at it.
If you can help me with schematic of manual, please, help me.... this is not a business.... a friend asked...it is a for free procedure.
Here is the image:
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0
Old 9th September 2008, 04:58 PM   #2
Default You know the idea...no emitter resistances results in no offset into the output
.. so...if the protection senses off set (burned transistors of circuit unballances) will not sense voltage there and protection will not enter into operation.
Seems there are other things to seach for.... i have removed the 5 channels emitter resistances and protection relay still enters.... so, other problems remains.
HELP!
regards,
Carlos
Old 9th September 2008, 10:09 PM   #3
Default No more needed... a good friend already have
E mailed the manual to me.
Three parts using Winrar.
thank you folks,
regards,
Carlos
Old 10th September 2008, 07:44 AM   #4
h_a is offline h_a  Europe
h_a's Avatar
Hi Carlos,
that corrosion is plain crazy!! Do all amps become like that in Brazil?
Have fun, Hannes
Old 10th September 2008, 09:57 AM   #5
Default Yes.... humidity is high and we leave very near the beach
Water temperature around 25 degrees Celsius and a really big quantity of salt into this watter.... 500 kilometers north direction people use to produce salt evaporating water under the sunligth.
Interesting, the first 5 stages into appartment building are much more corroded.... i was living 16th floor and had no corrosion at all.
This equipment is not mine...the guy leaves third floor in front of the ocean...it seems this equipment is not too much old...maybe 3 years old maximum in my evaluation...boards are corroded, not only wire jumpers...under the green paint i could see copper lines corroded.
Well.... oxide happens into all places...but high humidity, nearby ocean...high temperatures that allow enormous evaporation, strong winds to replace the air surrounding object fast acelerates the whole process.
Appartment glasses needs to be cleaned withing 3 days space between cleaning.... you can feel into your fingers the salt into the windows...because of that our window frames are made of anodized aluminium.... weels made of nylon... cannot use iron or steel here.
regards,
Carlos
Old 10th September 2008, 10:21 AM   #6
Default This unit has serious "health" problems
Observe what is happening with those resistances....one year more and the leads will broke.
I said must remove transformers and all stuff that cannot receive watter and clean the unit..... and after dried apply oil, to protect a little, or some kind of insulating varnish... the owner said he prefere not to have the unit cleaned.
Well.... he will have unit corroded in one year or a little bit more.
People has beliefs... this is the problem....you know... "water and electricity cannot go together"....forbidden!.... people forget that water and electricity can be applied into different times...not the same time.... and you cannot explain that, because people will feel ofended....because you prove they failled into their intelligence use when having those worries... bad analisis!
ahahahaha.
Carlos
Old 10th September 2008, 10:31 AM   #7
Default Because of me?... his dennie!... no problems!
The guy is a friend.
In two years the equipment will be a junk...and will go to my own junk yard...and then i will have transformers, power transistors, heatsinks and some Alps potenciometers.... some relays.
I told him...so...i am not quilty!.... already have explained him the unit will end into my trash box because of oxide!
regards,
Carlos
Old 10th September 2008, 03:09 PM   #8
Default I already have the schematic folks.
Thank you.
Others are sending me links and files..... i already have...thank you...not needed anymore.
regards,
Carlos
Schematic Yamaha A-720 Macrom Solid State 3 7th April 2007 05:55 PM
Schematic for Yamaha A-550, anyone? Urban Solid State 2 24th May 2006 01:52 PM
YAMAHA DSP-A2 Schematic palesha Solid State 7 23rd December 2005 04:09 AM
needing schematic of amplifier of mic ary Multi-Way 3 16th September 2005 12:28 AM
Need Schematic of Yamaha PE-100 Sidereal Solid State 0 23rd February 2005 06:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
