Old 9th September 2008, 04:09 PM   #1
umut1001's Avatar
Default se max voltage
hi..i have some questions for experts..please dont answer if you are not an expert
1-how we decide the max or best voltage supply value of single ended symmetrical class a amps?(for this amp with irfp240 transistors)
2-i replaced irfp240 instead of irfp 150 in this circuit.mids and trebles increased and bass reduced..but i always see positive offset of 150mv..i can reduce it to 100mv only by playing trimpots..i can not reduce it anymore..which values of resistors should i change?
3-what is the technical criterias of sound quality for transistors?
is it low input capacitance?or low Qg?
thanks
best regards
umit
845 Low voltage SE AMP =maximum= Tubes / Valves 8 19th July 2007 10:56 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 07:41 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Page generated in 0.07241 seconds (54.66% PHP - 45.34% MySQL) with 11 queries
