Old 9th September 2008, 09:33 AM   #1
00940 is offline 00940  Belgium
Default Balanced shunt pot in front of a differential receiver
I don't really know in what forum to ask...
Can I put a simple shunt volume control in front of differential line receiver ? Just as attached, but without the two opamps buffering the inputs of the receiver. Any problems I might run into ?
It's to sum the outputs of a pcm1794 (after I/V conversion).
Ben.
Old 9th September 2008, 10:20 AM   #2
Did it Himself
richie00boy's Avatar
You would have to use low value resistors and a pot infront of the existing diff stage (inc resistors). This may mean that when the volume is attenuated a lot you place too much load on the driving stage.
Think of it as the same impednace problem with any passive pre-amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 9th September 2008, 11:43 AM   #3
What I had in mind:
4.7K resistors for the fixed resistors of the shunt and also 4.7K for the input resistor of the receiver. 22k resistors for the feedback around the opamp. A 10k stepped attenuator as shunt.
I can tailor the values of the attenuator to get true logarithmic attenuation. I'm not overly concerned by the current drawn by the shunt as the I/V stage is buffered by class A buffers iddling at 20ma. The whole thing is of course in the same box, no cables involved here.
Ben.
Old 9th September 2008, 12:09 PM   #4
Did it Himself
Doesn't sound too bad. There may be some funny curve characteristic due to interaction between the shunt and input resistors, but other than that OK I think.
Is there a reason you can't just use one side of the converter with a conventional unbalanced level control? As you seem to be ending up with an unbalanced output anyway.
Balanced Driver / Receiver arigy Solid State 11 14th June 2010 09:26 AM
Marantz SR7200 receiver - problem with front 2 channels willick Solid State 1 28th July 2008 03:20 AM
Balanced interconnect to differential amp - how would you do it? zigzagflux Tubes / Valves 11 5th February 2008 02:36 AM
What front end for PP - triode, pentode, mu-stage or differential triodes? ray_moth Tubes / Valves 13 29th May 2007 08:02 PM
Balanced / Differential Input Question thylantyr Solid State 2 28th March 2003 09:27 PM
Page generated in 0.10514 seconds (55.50% PHP - 44.50% MySQL) with 11 queries
