Old 7th September 2008, 01:25 PM   #1
fab is offline fab  Canada
fab's Avatar
Default Mix of GB and F5 Amps idea
This is the idea I came up while trying to increase the open loop gain of the F5 amp to have a higher more "load invariant" close loop gain (26 dB) . This is really only a mix of a GB-150 (Greg Ball "Amplifierguru") and Pass F5 amp topology. Also, I need a higher power so I plan to use it in class AB mode (about 10W class A and up to about 70W or so in class B) so I save a bit of money on my energy bill and the size of the case which has to pass the WAF...
The C25-C26 caps are bootstrap caps that could be included or not using a switch for audio comparison purpose.
Can you comment on any aspect of this design giving recommendations before I give it a try.... or not...
Old 7th September 2008, 03:56 PM   #2
juma is online now juma  Serbia
juma's Avatar
I don't know if NTC1 and NTC2 would be sufficient to prevent thermal runaway in output MOSFETs - you plan to run the amp in AB class, it's quite different scenario compared to F5
I'd rather go for Vgs multiplier for ensuring thermal stability.
Old 7th September 2008, 10:45 PM   #3
fab's Avatar
This a valuable comment. I have never used IRFPxxx devices before. I have used IRF340 before (both in class A and class AB)which are also vertical mosfet devices but different than IRFPxxx devices.
Where would you put the VGS multiplier in this design?
Does someone knows how is done the temperature compensation in the "SKA" amp (GB150)?
Old 7th September 2008, 11:27 PM   #4
darkfenriz's Avatar
I don't know for sure but probably manipulating tail current of long tail pairs
Old 7th September 2008, 11:43 PM   #5
fab's Avatar
You mean in SKA amp because I do not have a long tail pair...
In my schematic, would that be similar to use a NTC like I have shown?
Old 8th September 2008, 09:14 AM   #6
juma's Avatar
AFAIK, SKA uses Lateral MOSFETs (BUZ 9xx) so the temp. comp. is not needed.
You should put Vgs multiplier between the emitters of Q5 and Q6 in you schematic. SEARCH button is your friend
Old 8th September 2008, 11:03 AM   #7
djk is offline djk
djk's Avatar
They are IRF type FETs, and the Vgs are matched within 10mV. Photo shows a pair of TO-92 devices attached to the heatsink for thermal tracking.
http://www.ska-audio.com/diy/Compone...0x200_150d.jpg
Candidates for the Darwin Award should not read this author.
Old 8th September 2008, 01:24 PM   #8
juma's Avatar
Yes, you are right, the picture clearly shows temp. comp. transistors and IRF MOSFETS. I was seduced by old pictures showing BUZ9xx devices.
Old 8th September 2008, 01:34 PM   #9
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
BC546/556
Looks like Sponge Bob has killed another thread.
Old 8th September 2008, 03:12 PM   #10
bogdan_borko's Avatar
I guess you could use Q5 and Q6 for temperature compensation as they are in mosfets gate-source circuit but you have to experiment with R62/64 and R59/60.
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
TCJ - Evolve simply and good amps idea padamiecki Solid State 35 11th January 2007 12:12 PM
Page generated in 0.14687 seconds (57.82% PHP - 42.18% MySQL) with 11 queries
