can anyone help with CCS can anyone help with CCS - Page 2 - diyAudio
Old 6th September 2008, 07:05 PM   #11
onform is offline onform  United Kingdom
onform's Avatar
thats good,
so the 1M resistor needs to go where? inbetween the transistors is that correct?
What value resistors do you think at R1 and R2 for 3.1vf??
this is stupid but the supply will not fry the first few led's will it.....it will increase V according to demand from the LED's..is that correct?? or am i getting it the wrong way round??
Old 6th September 2008, 07:20 PM   #12
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
That's the entire point of current source drive, lol that's what you asked for anyway.
Use ohm's law to work it out for different Vf
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th September 2008, 07:41 PM   #13
onform's Avatar
I know i know...being new and still learning i'm constantly not sure if what i'm doing is correct...lol Re the resistors, no free lunch aye..lol
matt
Old 6th September 2008, 08:08 PM   #14
Did it Himself
I'll run through it as you might get caught out with a couple of things.
We know the CCS is running at 5mA so that gives 2.5mA in the LED and 2.5mA in the resistor. We can see using the values I have above that the voltage across the resistor is 0.0025A * 560R = 1.4V, then there is the Vbe to take into account, 2.1 - 1.4 = 0.7 with the transistors shown.
So now with LEDs of Vf = 3.1V let's see what happens. Resistor voltage will be 3.1 - 0.7 = 2.4. We want 2.5mA in the resistor so that means we need 2.4V / 0.0025A = 960 ohms.
Vf is quoted at 2.1V (or 3.1V for your LEDs), but this figure does vary a bit with current and is usually stated at full current which you won't want to run at. So some tweaking may be necessary, but it's probably close enough for what you want.
Old 6th September 2008, 08:39 PM   #15
rocco gibralter is offline rocco gibralter  United Kingdom
Dont want to sound snobby, But LED's mess up the sound making it grainy, I'd fit a switch to turn them all off when your listening to music........
But dont let me sway you!
Old 6th September 2008, 10:07 PM   #16
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Neat idea but it's going to need a supply voltage of 24x Vf yielding 74.4 volts even before the CCS headroom is taken into account. Also maybe the knob will be a bit stiff with two lots of switches on it?
Anyway I have a good little circuit for you here.
R3 is the load i.e. your string of LEDs. As shown with LEDs having Vf=2.1 used for the CCS it's running at 5mA. If you use your blue LEDs having different Vf then you will need to change the 560 ohm resistors R1 and R2. The transistors shown will be fine for the application but small heatsinks are needed. The supply voltage should be 82-100 volts.
With good transistors used it will never start, so you need one more resistor to provide some initial current.
The Devil is not so terrible as his math model is!
Old 6th September 2008, 10:16 PM   #17
sawreyrw is offline sawreyrw  United States
Wavebourn,
onform told us that in post #11.
Rick
Old 6th September 2008, 10:34 PM   #18
Wavebourn's Avatar
Originally posted by sawreyrw
Wavebourn,
Oops... I did not read all posts carefully. Anyway, a reminder would not be odd.
Old 7th September 2008, 09:34 AM   #19
Did it Himself
However I have built a few of these and never used the resistor and never had a problem. Also it always sims perfectly without
It would not hurt to include the resistor for keeping theorists happy though
Old 7th September 2008, 02:46 PM   #20
onform's Avatar
Default thats good..
I'll run through it as you might get caught out with a couple of things. .
Thanks a lot that answers a few Q i was about to ask...lol just designing the pcb for the switch and supply at the mo,
This all operates outside of the amp cicuit and has it's own supply I will probably sheild the supplies from the main amp board anyway but thanks for the comment it will be interesting to see if it does affect anything. a simple swith can be addded later if it does.
I will probably try it without first but add in the provision for it when printing the boards..again we shall see...
thanks guys...
can anyone help with CCSHide this!Advertise here!
Copyright ©1999-2017 diyAudio
