Line stage modification
Old 30th October 2008, 01:04 PM   #11
Predator864 is offline Predator864  Europe
Thank you lineup.
What substitute should I use for 2SC1740/2SA933 ?
I have for the moment the MJE340/MJE350.
50V/0.15A vs 300V/0.5A.
Should I use this 2 transistors with a higher supply voltage ?
Also I would like a higher bias, if possible.
Old 30th October 2008, 02:17 PM   #12
lineup is offline lineup  Sweden
lineup's Avatar
how much bias is the output?
Voltage across R360/value of R360, 68 Ohm = Current
Volt/68ohm=current in resistor
you should not need more than 2-5 mA Class A for best result
(to drive any power amp input)
the 4 input transistors works at ~0.3 mA per each
thi is a good value and should NOT be raised to more than ~0.5 mA
(the current in each is like 50 % of current in 22k resistor=
Volt/22k= current in resistor
Replacements:
2SC1740S:
BC550C, 2SC2240 ... TO-92 low noise, high gain NPN
2SA933S:
BC560C, 2SA970 ... TO-92 low noise, high gain PNP
I would not go more than 0.5 mA for each input transistor
Example: use 15k (instead of 22k)
15Volt/15k = 1 mA
1 mA/2 = 0.5mA for each T
I would not use more than 5 mA for output stage transistors
0.340 Volt across 68 Ohm resistors
lineup
Old 30th October 2008, 09:41 PM   #13
lineup's Avatar
Predator864
These are the values I would used.
With R2, R14 at 2k2, the output stage will idle at 3.8 mA Class A.
This would be well enough for 99% of everything one Line preamp will need to do.
The gain is bit below x4.
-3 dB bandwidth, with my capacitors: 4 - 800.000 Hz
Distortion 1Vrms/10kohm output: < -100 dB for all harmonics.
(-100 dB = 0.001 %)
Not bad for 6 standard BC550C/560C TO92 transistors!
Enjoy
lineup
Line stage modificationHide this!Advertise here!
Zoom H2 modification; now with 4 line inputs Bertoa Everything Else 6 15th June 2013 10:22 PM
Micromega Stage 2 modification - and incorrect info... jono799 Digital Line Level 59 13th June 2011 07:27 AM
Which DHT for Line stage? andyjevans Tubes / Valves 15 26th March 2009 02:10 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 10:50 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
