Measuring low noise - Page 4 - diyAudio
Old 8th September 2008, 02:38 PM   #31
jackinnj's Avatar
Default Re: Re: Measuring 1/F noise
Originally posted by scott wurcer
I once went down to 11 micro-Hz with one of those characterizing current noise.
At 11uHz can't you just see the little critter comin' and whack it with a shovel?
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 9th September 2008, 02:03 AM   #32
unclejed613's Avatar
let's see..... that's 90,000 seconds of averaging time.......
just over a day...
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 4th March 2014, 02:14 PM   #33
jackinnj's Avatar
Originally Posted by scott wurcer View Post
For maximum versatility you could use an instrumentation amplifier. There are many already available or you could build this little circuit. The FET's need to be matched or you need a big AC coupling cap in series with the gain resistor which goes between the sources of the input FET's.
I wonder if you've given more thought to that circuit (post 17) after writing up the two-part Linear Audio articles on microphone preamplifiers. I've built a couple versions with both BF862 and K170 and an LME49720 opamp.
I recommend the transistor matching device you showed in the LA article.
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 10:42 AM
A novice scope user - measuring noise? phrarod Tubes / Valves 15 15th July 2009 04:14 AM
Multisim: Measuring Noise underwurlde Power Supplies 0 29th May 2008 10:32 PM
measuring the noise of a power supply pjpoes Power Supplies 6 31st March 2008 07:19 PM
WTB:PCB for low noise measuring amp Ryssen Swap Meet 4 15th August 2007 04:24 PM
Copyright 1999-2017 diyAudio
