#51 |
Forr,
you got mail
#52 |
Amazing opamp measurement shoot-out:
http://recforums.prosoundweb.com/index.php/t/24704/0/ Any kind of shootout, will be biased in some way, by the intent, the hypothesis or desire of the investigator. - selection of objects to test - selection of parameters to test - and parameters not to test - selection of data presentation of test result - the conclusive statement, opinion of the tester Nevertheless, any such comparing test performed can give us some useful additional knowledge and information. So is very welcome
lineup |
#53 |
Here is the PDF Document for download
Operational Amplifier Distortion by Samuel Groner, 1 September 2008 http://www.sg-acoustics.ch/analogue_...distortion.pdf
lineup |
#54 |
Notice that Scott Wurcer is mentioned in the reference list:
[13] Scott Wurcer: An Operational Amplifier Architecture with a Single Gain Stage and Distortion Cancellation AES preprint No. 3231, March 1992 Along with such great men as Douglas Self Walter G. Jung
lineup |
#55 | |
In this preprint Scott describes the design of the AD797. And while I have a lot of respect for WJ, please note that Scott is an IC designer while Walt is an application engineer. Different roles. Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#56 | |
I´m thinking on changing it back to 4580.Is the 4580 realy that bad that everyone is saying?
Regards Åke |
#57 |
I think there's a bunch of those in the Echo Audiofire4 and that converter is close to transparent in loopback so I think calling that IC bad would be a stretch and then some. :-)
/Peter |
#58 | |
I now Denon DVD3910 uses them,any more expensive than that?
Regards Åke |
#59 | |
The THS4031 do have an higher bias (close to a class A) than most Ic. For myself I allway use my Ic into class A with a resistor or a CCS from rail to ouput, but the THS4031 may not need it since its high bias. Thank Bye Gaetan |
#60 |
At the risk of being run out of town, I keep coming back to the LF353
I have used several of the other amps including the LM4580. The key I think is to use these op amps at high frequency gains less then 5 The phono stage uses a low noise bipolar front end (Av =20) overall s/n = 93db. I noticed that this amp (LF358) had very linear distortion curves. In practice , it is almost impossible to get them to oscillate with an appropriate output decoupling resistor. The latest project has a LF353 a/d 1st stage in my 1.3 mhz class d amplifier with spectacular results. |
| SWR t-shoot question | ReldvS | Solid State | 3 | 11th August 2009 12:01 AM |
| TB shoot out long | RAW | Multi-Way | 0 | 1st August 2003 08:18 PM |
| TB/MCM 8" shoot out | RAW | Multi-Way | 2 | 20th October 2002 03:52 AM |
| Page generated in 0.10482 seconds (81.66% PHP - 18.34% MySQL) with 11 queries |
